Show integral is independent of time
The discussion focuses on proving that the integral \( I_1 = \int_{-\infty}^{\infty} u^2 dx \) is independent of time for the equation \( u_t - 6uu_x + u_{xxx} = 0 \). Participants suggest using the Leibniz integral rule and substituting \( u_t = 6uu_x - u_{xxx} \) to evaluate the time derivative \( \frac{\partial I_1}{\partial t} \). The conversation highlights the importance of integrating by parts and recognizing that certain integrals evaluate to zero, confirming the independence of \( I_1 \) from time.
  • Understanding of partial differential equations (PDEs)
  • Familiarity with the Leibniz integral rule
  • Knowledge of integration techniques, including integration by parts
  • Experience with evaluating limits at infinity in integrals
  • Study the application of the Leibniz integral rule in more complex scenarios
  • Learn about the properties of integrals involving limits at infinity
  • Explore advanced techniques in solving partial differential equations
  • Investigate the implications of conservation laws in fluid dynamics
Mathematicians, physicists, and engineers working with fluid dynamics and partial differential equations, particularly those interested in the conservation properties of integrals over time.
motherh
Given that u(x,t) satisfies u_t-6uu_x+u_{xxx}=0 (*) and u, u_x, u_{xx} \to 0 as |x| \to \infty show that
I_1 = \int_{-\infty}^{\infty}u^2dx
is independent of time (\frac{\partial I_1}{\partial t}=0).
I guess it would suffice to show that I_1 is equal to some function of (only) x. I can't think of a way to do this which involves the equation (*). My attempt so far has been to do some kind of substitution so that I integrate with respect to u rather than x. Something like
I_1 = \int_{-\infty}^{\infty}u^2dx = \int_{u(-\infty,t)}^{u(\infty, t)}u^2 \frac{dx}{du} du = \int_{0}^{0} \frac{u^2}{u_x} dx = 0
Am I on the right track?
That doesn't seem right to me. Use Leibniz integral rule for differentiating the derivative w.r.t. time and then use the differential equation for substitution.
As "Shyan" has already suggested, you can show that ##I_1## is a constant by showing that ##dI_1/dt = 0##.
Thanks guys.
I've given your advice a go. So far I have used Leibniz integral rule and f=u^2:
\frac{\partial I_1}{\partial t} = \frac{\partial}{\partial t}(\int_{-\infty}^{\infty} f(x,t)dx) = \int_{-\infty}^{\infty} \frac{\partial f}{\partial t} dx = \int_{-\infty}^{\infty} uu_tdx.
Where do I go from here?
motherh said:
Thanks guys.
Are you forgetting that ##u## satisfies a partial differential equation? You have all the information you need; it is just a matter of applying it.
I thought about subbing in u_t=6uu_x-u_{xxx} to get
6\int_{-\infty}^{\infty}u^2u_xdx-\int_{-\infty}^{\infty}uu_{xxx}dx.
I can compute the first integral to get \frac{1}{3}u^3 evaluated at -\infty to \infty (so that integral is equal to 0) but I can't do anything with the second integral. I had this problem last night but decided to sleep on it - unfortunately that didn't help!
Right, I got it thanks!
There's another part to the question, it's pretty much the same as part one but now for
I_2=\int_{-\infty)^{\infty}(u^3+\frac{1}{2}u_x^2)dx.
I got it down to
\frac{\partial I_2}{\partial t}=3\int_{-\infty)^{\infty}u^2u_tdx + \int_{-\infty)^{\infty}u_xu_{xt}.
Now subbing in u_t=6uu_x-u_{xxx} and u_{tx}=6u_x^2+6u_{xx}-u_{xxxx} gives a few difficult integrals to solve. I can do three of them but the other two I can't get past are
\int_{-\infty)^{\infty}u^2u_{xxx}dx and \int_{-\infty)^{\infty}u_x^3dx.
Have I made a mistake to get to this point? If not, are these integrals possible?
I_2 = \int_{-\infty}^{\infty}(u^3+\frac{1}{2}u_x^2)dx.
I got it down to
\frac{\partial I_2}{\partial t}=3\int_{-\infty}^{\infty}u^2u_tdx + \int_{-\infty}^{\infty}u_xu_{xt}.
\int_{-\infty}^{\infty}u^2u_{xxx}dx and \int_{-\infty}^{\infty}u_x^3dx.
That seems right. But you can also use u_{xt}=u_{tx} and integrate by parts to eliminate the x derivative. Then substitute using the differential equation. But I'm stuck at the end too! My problem is I can't deal with \int_{-\infty}^{\infty} u u_x u_{xx} dx. If you prove this is zero, then its finished.
EDIT: I found it. There are two such integrals which cancel each other and give zero. This was nice!
I'm really sorry, I don't follow what you're saying. How is u_{xt} = u_{tx} useful and what should be integrated by parts?
\int_{-\infty}^{\infty} u_x u_{tx}dx=-\int_{-\infty}^{\infty} u_{xx} u_t dx.
I just wanted to point out that ##I_1## is actually a function of ##t## only. So, you shouldn't be using the partial derivative wrt ##t##.
You need to be careful to check what sort of function you have - especially when you're using condensed notation. It's often better to put the variable(s) in so that can see what you're doing:
I_1(t) = \int_{-\infty}^{\infty}u(x, t)^2dx
So far I have
\frac{\partial I_2}{\partial t} = \frac{\partial}{\partial t}\int_{-\infty}^{\infty}(u^3+\frac{1}{2}u_x^2)dx = 3\int_{-\infty}^{\infty}u^2u_tdx + \int_{-\infty}^{\infty}u_xu_{xt} = 3\int_{-\infty}^{\infty}u^2u_tdx - \int_{-\infty}^{\infty}u_{xx}u_tdx
\int_{-\infty}^{\infty}u^2u_tdx = 18\int_{-\infty}^{\infty}u^3u_xdx-3\int_{-\infty}^{\infty}u^2u_{xxx}dx.
\int_{-\infty}^{\infty}u_{xx}u_tdx= -6 \int_{-\infty}^{\infty}u_{xx}u_xdx + \int_{-\infty}^{\infty}u_{xx}u_{xxx}dx.
I can compute all of these integrals (to be 0) but not \int_{-\infty}^{\infty}u^2u_{xxx}dx. If I can compute that integral then I'm done.
I didn't come across \int_{-\infty}^{\infty}uu_xu_{xx}dx at all.
As PeroK noted, you should write \frac{dI_2}{dt} because a definite integral on x of a function of x and t, is no more a function of x.
Anyway, you did it wrong! u_{xx}u_x should be u u_{xx} u_x. And the term you can't evaluate, can be integrated by parts to give a similar term.
I've got it! Thanks so much for all of the help, I certainly needed it!
  • · Replies 16 ·
