Show that arctan(x/2) = arccos(2/√(4+x²))
  • Thread starter Thread starter ][nstigator
    Trig
7 replies · 3K views
][nstigator
Hey guys, got a small problem and need some help :frown: Homework Statement
Show that
[tex]\arctan{\left( \frac{x}{2} \right)} = \arccos{\left(\frac{2}{\sqrt{4+x^2}}\right)} \ \mbox{for x}\epsilon\mbox{R}[/tex]
The attempt at a solution
Honestly I am pretty stumped from the very beginning...
The only thing I can currently think of to do is go...
[tex]\arctan{\frac{x}{2}} = \frac{\arcsin{\frac{x}{2}}}{\arccos{\frac{x}{2}}}[/tex]
but I am not sure if that is even correct...
Even still, if that is valid, I am still pretty unsure what I am meant to do next..
Any hints to point me in the right direction would be much appreciated :redface:
I hope I did the Latex stuff right, its my first time using it..
Draw a right-triangle and label the sides until you can form a triangle which give s the relationship that you are looking for in your equation. This may give you another formulable relationship which permits you to solve the problem.
I misunderstood the meaning of the problem. You are probably looking for identity relationships to PROVE that your given relation is an identity. Of course, when you draw a right-triangle, you will be able to derive the relationship but you are trying to use a trail of identities to prove this. I wish I could offer better help.
The best that I could do right now is to draw a triangle; I label one of the non-right angles; the side opposite I give as "x"; the side between the referenced angle and the right-angle I give as length 2; pythagorean theorem gives the hypotenuse as (4 + x^2)^(1/2). Continued reference to this triangle gives the arcos expression which you wanted -------- I am not well with being able to prove as you wanted, but maybe you might be able to now?
:confused:
Are you sure you've copies the problem correctly?
What if [tex]x = -2[/tex]?
[tex]\arctan \left( \frac{-2}{2} \right) = \arctan (-1) = -\frac{\pi}{4}[/tex]
Whereas:
[tex]\arccos \left( \frac{2}{\sqrt{4 + (-2) ^ 2}} \right) = \arccos \left( \frac{1}{\sqrt{2}} \right) = \frac{\pi}{4}[/tex]
So:
[tex]\arctan \left( \frac{-2}{2} \right) \neq \arccos \left( \frac{2}{\sqrt{4 + (-2) ^ 2}} \right)[/tex] (Q.E.D)
:smile:
Yup, I definitely copied the problem down correctly... weird huh :(
Either you are not working in principle values or the question is copied down incorrectly.
because [itex]cos \frac{\pi}{4}= cos \frac{- \pi}{4}[/itex]
but the inverse doesn't hold as [itex]cos^{-1} \mbox{has principle range as} [0,\pi][/itex]
Show that [tex]\arctan{\left( \frac{x}{2} \right)} = \arccos{\left(\frac{2}{\sqrt{4+x^2}}\right)} \ \mbox{for x}\epsilon\mbox{R}[/tex]
..is the question, character for character :frown:
