Show that $\beta$ is Algebraic over $F(\alpha)$ in Simple Extensions
  • Thread starter Thread starter ehrenfest
The problem involves showing that if \(\alpha\) is transcendental over a field \(F\) but algebraic over the extension \(F(\beta)\), then \(\beta\) must be algebraic over \(F(\alpha)\). The discussion centers on the properties of algebraic and transcendental elements in field extensions.
  • Mixed
  • Participants explore two cases regarding the nature of \(\beta\): whether it is algebraic or transcendental over \(F\). They discuss the implications of \(\alpha\) being transcendental over \(F\) and algebraic over \(F(\beta)\). There are attempts to express relationships between polynomials in \(F(\beta)\) and \(F(\alpha)\), questioning how to manipulate infinite series and products.
There is ongoing exploration of the relationships between the elements and their respective fields. Some participants suggest reorganizing terms to clarify the structure of the polynomials involved. Others express uncertainty about the manipulation of infinite series and whether such operations yield valid polynomials or power series.
Participants note the complexity introduced by infinite sums and products, questioning the validity of operations involving them. There is also mention of the need for finite coefficients in the context of obtaining a polynomial of finite degree.
ehrenfest
Let E be an extension field of F, and \alpha,\beta \in E. Suppose \alpha is transcendental over F but algebraic over F(\beta). Show that \beta is algebraic over F(\alpha).
I think it makes sense to divide into two cases:
Case 1: \beta is algebraic over F
It is obvious that if \beta is algebraic over F then, \beta will be algebraic over any extension field of F, right?
Case 2: \beta is transcendental over F
In this case, \phi_{\beta}(F[x]) is only an integral domain, so F(\beta) is the field of quotients of \phi_{\beta}(F[x]), call it G. Because \alpha is transcendental over F, we know that F(\alpha) is the field of quotients of \phi_{\alpha}(F[x]), call it H. It is obvious that G and H are subfields of the field E. We know that there is an irreducible polynomial p(x) in G that has \alpha as a zero. But we want a polynomial in H[x] that has \beta as a zero.
Say p(x) = \sum_{i=0}^{\infinity}a_i x^i. Then p_{\alpha} = \sum_{i=0}^{\infinity}a_i \alpha^i. But what are the a_i? They are elements of G. Thus, we can rewrite p(\alpha) as
\sum_{i=0}^{\infinity}\frac{\sum_{j=0}^{\infinity}f_{ji} \beta^j}{\sum_{h=0}^{\infinity}f_{hi} \beta^h} \alpha^i
where we know that f_ji and f_hi are in F. We know that must equal 0. That is:
\sum_{i=0}^{\infinity}\frac{\sum_{j=0}^{\infinity}f_{ji} \beta^j}{\sum_{h=0}^{\infinity}f_{hi} \beta^h} \alpha^i = 0
Thus we multiply both sides by \prod_{k=0}^{\infinity}\sum_{h=0}^{\infinity}f_{hk} \beta^h to get:
\sum_{i=0}^{\infinity}\left( \prod_{k\neq i}^{\infinity}\sum_{h=0}^{\infinity}f_{hk} \beta^h \right) \sum_{j=0}^{\infinity} f_{ji} \beta^j \alpha^i = 0
Is this getting anywhere?
anyone?
I think that if \alpha is transcendental in F, and algebraic in F(\beta), \beta is going to be transcendental in F as well.
You're close to the finish line. Simply regroup so that you've got things in order of powers of \beta.
If beta is algebraic in F, and alpha is algebraic in F(\beta), then we have a polynomial p(x) in F(\beta)[x] that has alpha as a zero. Thus,
p(\alpha) = \sum_{i=0}^{\infty}\left(\sum_{j=0}^{\infty}f_{ji}\beta^j \right)\alpha^i = 0
Why does that imply that \alpha is algebraic over F?
Leaving the line in the proof is fine, but I think if \beta is algebraic in F then it should be possible to multiply any polynomial in F(\beta) by conjugates to get a polynomial in F since \beta can be written as an expression involving roots in F.
I assume you manged to finish the proof.
No. I did not finish the proof. So, I need to convolve an infinite product of formal polynomials, right? I can convolve two, but I have no idea how to convolve an infinity number of them. Is multiplication by an infinite number of polynomials even defined for formal power series? Don't you get infinite coefficients?
Sorry, I missed that in the first post. Are you sure the sums should be infinite?
Well, the sum over i is a formal power series. But we know that only finitely many of the coefficients of powers of alpha are nonzero. So, I guess you could write it as:
\sum_{i_n}^{\infinity}\frac{\sum_{j=0}^{\infinity} f_{ji_n} \beta^j}{\sum_{h=0}^{\infinity}f_{hi_n} \beta^h} \alpha^{i_n} = 0
where n is the index set of the i's that index nonzero quotients of polynomials. So, then
\sum_{i_n=0}^{\infinity}\left( \prod_{k_m\neq i_n}^{\infinity}\sum_{h=0}^{\infinity}f_{hk_m} \beta^h \right) \sum_{j=0}^{\infinity} f_{ji_n} \beta^j \alpha^{i_n} = 0
where m is the same index set as n.
So, then it is a finite product. So now you think I can convolve things to get a polynomial in beta?
Unless the sums in the quotient are finite, you can't get a polynomial of finite degree. (You'll get a power series instead.)
No. You'll get \beta^\infty unless the sums in the quotient are finite.
