Show that for all n ∈ Z (>0), g(n) > f(n)
  • Thread starter Thread starter gex
The discussion revolves around proving that for all positive integers n, the function g(n) is greater than the function f(n). Participants explore various mathematical approaches, including graphical analysis and the use of integrals and Riemann sums.
  • Participants discuss graphing the functions f(n) and g(n) to visually assess their relationship. There are inquiries about how to rigorously prove the inequality using mathematical concepts such as integrals and areas under curves.
Some participants have provided guidance on interpreting the functions in terms of areas and rectangles, while others express uncertainty about specific mathematical concepts. The discussion is ongoing, with multiple interpretations being explored and no explicit consensus reached.
There are references to a teacher's hint that some participants find unclear, and the discussion includes attempts to clarify the relationship between the functions through graphical and integral methods.
gex
The attempt at a solution
Hi there, in an attempt to prove that g(n) is greater than f(n), I graphed both functions on the same axes and it is visually obvious that g(n) is greater than f(n), but I am not sure how I would go about proving this for all positive integers in a mathematically rigorous way. Any guidance is greatly appreciated.
Thread moved. Please post questions involving integrals in the Calculus & Beyond section, not in the Precalc section.
Which "both functions" did you graph?
Think about f(n) as an area under a graph, and g(n) as the sum of areas of rectangles.
The above picture displays the graphs of f(n) and g(n) generated by https://www.desmos.com/calculator
I understand what you mean by thinking about f(n) as an area underneath a graph, but am quite unsure how g(n) represents the sum of areas of rectangles. I would appreciate some clarification this if possible, thank you.
Can you convert the sum for g(n) into an integral of a new function that matches the sum for each integer n?
I would shift the graph of the sum by 1/2 to the right, that makes it easier to see.
Those aren't the right graphs. What I was talking about was graphing y = 1/x on the interval [1, n] for f, and comparing this to the graph of y = 1/j on the same interval for g, using a Riemann sum.
I'm really not sure how I would go about doing that, I've never encountered such a thing before in my studies.
Sorry but I'm not quite sure what that is.
My teacher provided a hint for this question to the class that I don't understand either, and I'm not sure where this hint is supposed to lead me.
Your teacher's hint is what I was suggesting in my post.
In the inequality in your teacher's hint, look at the interval [k, k+1] on the x-axis. Draw a rectangle whose width is 1 and whose height is 1/k. What's the area of this rectangle? (Easy question)
Also draw a curve from the point (k, 1/k) to the point (k + 1, 1/(k + 1)). The region under the curve is the integral in your teacher's hint. Which area is larger?
BTW, the graph you included in post #3 really is irrelevant in this problem, which is why I said earlier that you have drawn the wrong graphs.
The area for such a rectangle would equal 1/k.
Substituting 1=k shows me that the area for the rectangle is larger than the region underneath the curve. Which makes sense as this shows that g(n) > f(n). But how would I go about proving this for all values of k ∈ Z ?
Pick an arbitrary interval, [k, k + 1]. If g(x) > f(x) is true on an arbitrary interval, it's true for each one of them.
Thank you for your help Mark, I finally solved the problem :)
