Show that it satisfies the differential equation
11 replies · 8K views
crybllrd
Show that
[tex]y=tanh(t)[/tex]
[itex]\frac{dy}{dt}=1-y^{2}[/itex]
with initial conditions y(0) = 0
I'm not sure how to start, but we have only dealt with one D.E., and we had moved all the variables to a respective side then integrated.
[itex]dy=(1-y^{2})dt[/itex]
[itex]\frac{dy}{1-y^{2}}=dt[/itex]
Integrate both sides to get
[itex]ln|1-y^{2}|=t[/itex]
Not sure where to go from here
hi crybllrd! :smile:
nooo :redface:
d/dy (ln(1 - y2)) = 2y/(1 - y2)
try again, splitting 1/(1 - y2) into partial fractions first :wink:
Oh ok , I got it. I am in Calc 2 and when I read Diff. Eq. it just scared me off.
That was easy enough. It is a seven part question, and the third part looks very similar:
Show that for the arbitrary constants A and B, the function y=Atanh(Bt) satisfies:
[itex]\frac{dy}{dt}=AB-\frac{B}{A}y^{2}[/itex]
I will try to get it to match the form:
[itex]\int\frac{1}{A^{2}+x^{2}}=\frac{1}{A}tan^{-1}(\frac{x}{A})+c[/itex]
_______________________________________________________
[itex]dy=B(A-\frac{1}{A}y^{2})(dt)[/itex]<--- factored out the B and multiplied by dt
[itex]\frac{dy}{A-\frac{1}{A}y^{2}}=Bdt[/itex]
It looks like I need to do a little more manipulation/simplification to get the left side where I want it (namely getting rid of the 1/A in the denominator) but I can't get it to the form I want.
No, no, no! Did you not understand what sheriff89 said? You are not asked to solve the differential equation. In Calculus II you wouldn't be expected to do that.
Differentiate y= Atanh(Bt) and put it and [itex]y^2= A^2tanh^2(Bt)[/itex] into the equation and determine if you get a true equation or not.
Why would I put the y^2 into the equation and square the other side? And what is a "true equation"?
I have a feeling these will be on our exam next week, so I want to understand it well.
Thanks
You still aren't getting the point of just substituting into the differential equation to show you have a solution. Go back to the first one. If y=tanh(x) then dy/dx=sech(x)^2. The other side is 1-y^2=1-tanh(x)^2. Aren't they equal? You don't have to solve any ODE's, you just have to show you have a solution.
Oh ok I get it.
On part A I algebraically rearranged to get dy/(1-y^2 )=dt, then I integrated both sides to get (after simplification) y= tanh⁡t, done. Just did it the long way, not even thinking because all the other problems were integration.
then, when I started integrating part b, people starting getting upset :P
So this is what I have for part b:
y(t)=Atanh(Bt)
y(t)'=ABsech2(Bt)
y(t)'=AB-(B/A)y2
ABsech2(Bt)=AB-(B/A)Atanh2(Bt)
B's cancel out
Asech2(Bt)=A-tanh2(Bt)
I can see this being true if A=1
Is that all I need?
And, where does the y(0)=0 come into play? I see where that is true, but is that information actually needed to solve it?
y(t)^2=A^2*tanh(Bt)^2. If you work it out correctly the A factor will cancel as well. And you don't need y(0)=0 to show that. But given the solution, you can say y(0)=0.
Cool, thanks a lot.
I think I'm definitely ready for an exam on Monday.
EDIT: I had a math error on my last post when I substituted for y2. When done properly, all the A's canceled out.
Ugh, this problem is killing me. On a later part, it asks:
Let v(t) be the velocity of a falling object of mass m that started from rest. For large velocities, air resistance is proportional to the square of velocity v(t)2.
If we choose coordinates so that v(t)>0 for a falling object, then there is a constant k>0 such that
[itex]\frac{dv}{dt}=g-\frac{k}{m}v^{2}[/itex]
Solve for v(t) by applying the rsults of part (b) (what I just worked out) with
[itex]A=\sqrt{gm/k}, B=\sqrt{gk/m}[/itex]
I am not sure what "result" he is wanting from part B, I just had to show that a function satisfied a differential, and in doing so I canceled out all of the constants except for the B within the hyperbolic.
You know that v(t)=A*tanh(Bt) satisfies [itex]\frac{dv}{dt}=A B - \frac{B}{A}v^{2}[/itex]. So to find a solution to [itex]\frac{dv}{dt}=g-\frac{k}{m}v^{2}[/itex] you just set [itex]A B=g[/itex] and [itex]\frac{B}{A}=\frac{k}{m}[/itex] and solve for A and B. But it looks like they already did that for you as well. So maybe they just want to to substitute those values for A and B into v(t)=A*tanh(Bt)? Or maybe they want you to show explicitly that it works?
