Show the pre-image of a vertical line Re(w)=c under f
  • Thread starter Thread starter Raziel2701
    Line Vertical
The pre-image of a vertical line Re(w)=c under the function f(z) = i(1-z)/(1+z) is a circle centered on the line Re(z) = -1 and tangent to the real axis Im(z) = 0. The calculation of Re(z) yields Re(z) = (-c² + 1)/(c² + 1). The intersection of this circle with the unit circle |z| = 1 occurs at two points, forming a right angle. The analysis confirms the geometric properties of the transformation defined by the function f.
  • Complex analysis fundamentals
  • Understanding of complex functions and mappings
  • Knowledge of circle equations in the complex plane
  • Familiarity with limits and continuity in complex functions
  • Study the properties of Möbius transformations
  • Learn about the geometric interpretation of complex functions
  • Explore the concept of pre-images in complex analysis
  • Investigate the intersection of circles in the complex plane
Students of complex analysis, mathematicians exploring geometric transformations, and anyone studying the properties of complex functions and their mappings.
Raziel2701
Show the pre-image of a vertical line Re(w)=c under f...
a) Show that the pre-image of a vertical line Re(w)=c under f is a circle centered on the line Re(z) = -1 and tangent to the real axis Im(z) = 0.
b) How does such a circle intersect the circle |z| =1?
Here's f by the way: i\frac{1-z}{1+z}
So I took f and set it equal to c:
i\frac{1-z}{1+z} =c
Solving for z, I get that the Re(z)
Re(z) = \frac{-c^2 +1}{c^2 +1}
So that was me not knowing what I'm doing and just messing with the given information. I then took the limit as z approaches infinity and I get -1, so I again, not knowing if I'm doing this right simply declared that Re(z) is now equal to -1 as I'm supposed to prove.
So am I doing this right?
For part b, the circles intersect twice at 90 degrees right?
f(z) is NOT equal to c, its real part is. The real part of any complex number, u, is equal to (u+ \overline{u})/2. Find that for this function
\overline{f}(z)= f(\overline{z})
and set it equal to 0.
