Showing a vector space is infinite dimensional
To show that the vector space \mathcal{F}(\mathbb{R}) of all functions from real numbers to real numbers is infinite dimensional, one can assume it is finite dimensional and derive a contradiction. By considering the functions f_n(x) = e^{nx} for n in \mathbb{N}, it is shown that if a finite set of these functions forms a basis, then the next function in the sequence, f_{n+1}, cannot be expressed as a linear combination of the previous functions, indicating linear independence. This leads to the conclusion that the finite set does not span \mathcal{F}(\mathbb{R}), contradicting the assumption of finite dimensionality. Ultimately, the proof suggests that there exists a linearly independent subset with infinitely many members, confirming the infinite dimensionality of \mathcal{F}(\mathbb{R}).
tylerc1991
This is only part of a problem I am working on, but the only part that I have questions about is the following:
Show that \mathcal{F}(\mathbb{R}) is infinite dimensional.
\mathcal{F}(\mathbb{R}) is the set of all functions that map real numbers to real numbers.
f_n is the function defined by the rule f_n(x) = e^{nx} for n \in \mathbb{N}
Suppose \mathcal{F}(\mathbb{R}) is finite dimensional.
This means that there exists a finite basis for \mathcal{F}(\mathbb{R}).
Consider the set of vectors \mathcal{E} = \{ f_1, f_2, \dotsc, f_n \} for some n \in \mathbb{N}.
Suppose \mathcal{E} is a basis for \mathcal{F}(\mathbb{R}), and consider the vector f_{n+1} in \mathcal{F}(\mathbb{R}).
Since \mathcal{E} spans \mathcal{F}(\mathbb{R}), we see that f_{n+1} \in \text{span}\{\mathcal{E}\}.
This means that
f_{n+1} = \sum_{k=1}^n a_k f_k = a_1 f_1 + a_2 f_2 + \dotsb + a_n f_n
for some a_1, a_2, \dotsc, a_n \in \mathbb{R}.
Equivalently, this means that
a_1 f_1 + a_2 f_2 + \dotsb + a_n f_n - f_{n+1} = 0. \quad \quad (1)
It has been shown that \{ f_1, f_2, \dotsc, f_{n+1} \} is linearly independent.
This means that each coefficient of f_i equals 0 for i = 1, 2, \dotsc, n+1.
But this is impossible, as -1 \neq 0.
Hence, \mathcal{E} does not span \mathcal{F}(\mathbb{R}).
I feel like I have't shown that \mathcal{F}(\mathbb{R}) is infinite dimensional.
It seems like I have shown that *some* finite bases do not work for \mathcal{F}(\mathbb{R}).
I think that I am close, but I think there is something missing.
Could someone point me in the right direction to finish this proof?
Thank you!
This means that
Where has this been shown? Certainly not in your work leading up to this statement. What you have is that {f1, f2, ..., fn} is a basis, so those vectors are a linearly independent set, but you haven't shown that {f1, f2, ..., fn, fn+1} is a linearly independent set.
Thank you!
You can also do this problem by showing there exist a linearly independent subset that has infinite many members (countably infinite is fine).
I mentioned at the beginning of the post that this question was part of a greater question that I am working on. I have shown that they are linearly independent, but for the sake of practicality I decided to leave it out.
True, but I have to appeal to the definition of a basis that we are using. By definition, a basis for a vector space V is a set that
i) is linearly independent
ii) spans V
The definition of span for an infinite set is the set of all finite linear combinations of elements of the set, so it would be awkward (I am thinking) so show that this infinite set spans the space.
OK then. Since you have already shown that the n+1 functions are lin. independent, which contradicts the (tacit) assumption that the dimension of your space is n.
Sheesh, taking mathematics to a whole new level of coldness :). Thank you for your (terse) help on the matter. The question is moot now anyway, as I can't assume what the functions are that span the space. Back to square 1 ...
Sorry, I didn't mean to seem brusque. All I meant was that with that new information (that you already showed that the n + 1 functions were linearly independent), your proof looked OK.
Do you have any more information than you've shown about the functions in your space? IOW, is there anything more given than they map a real to a real?
For example, if the functions are continuous and infinitely differentiable, they can be represented by Taylor series, with one possible basis being {1, x, x2, ...}.
