Showing Difference of Relatively Prime Polynomials is Irreducible
The discussion focuses on proving that the polynomial \( f - yg \) is irreducible in the polynomial ring \( K(y)[x] \) when \( f \) and \( g \) are relatively prime polynomials in \( K[x] \). The proof utilizes the existence of polynomials \( a, b \in K[x] \) such that \( af + bg = 1 \) and applies the Euclidean algorithm for polynomials. A contradiction arises when assuming \( f - yg \) is reducible, leading to the conclusion that \( f - yg \) cannot belong to the original ring of polynomials if \( y \notin K \).
  • Understanding of polynomial rings, specifically \( K[x] \) and \( K(y)[x] \).
  • Familiarity with the concept of relatively prime polynomials.
  • Knowledge of the Euclidean algorithm for polynomials.
  • Basic understanding of irreducibility in the context of polynomial algebra.
  • Study the properties of polynomial rings, particularly \( K[y][x] \).
  • Learn about irreducibility criteria for polynomials in multiple variables.
  • Explore the application of the Euclidean algorithm in polynomial factorization.
  • Investigate the implications of polynomial coefficients being constants versus variables.
This discussion is beneficial for algebra students, mathematicians studying polynomial theory, and educators teaching concepts of irreducibility and polynomial rings.
slamminsammya
Let K be a field, and f,g are relatively prime in K[x]. Show that f-yg is irreducible in K(y)[x].
There exist polynomials a,b\in K[x] such that af+bg=u where u\in K. We also have the Euclidean algorithm for polynomials.
Assuming towards a contradiction that f-yg were reducible, we have f-yg=hk where h,k\in K(y)[x] are not units. Then by the relative primacy condition we also have af+bg=1, so that multiplying both sides by hk yields hk(af+bg)=hk=f-yg, but this is a contradiction since f-yg is certainly not in our original ring of polynomials (assuming that y\notin K), but the left hand side is most certainly in the original ring. The problem is I don't feel confident at all in this argument. I am having trouble conceptualizing what f-yg is.
slamminsammya said:
...multiplying both sides by hk yields hk(af+bg)=hk=f-yg, but this is a contradiction since f-yg is certainly not in our original ring of polynomials (assuming that y\notin K),
Correct.
This is incorrect. Each part of the equation hk(af+bg)=hk=f-yg was derived by directly applying noncontradictory definitions (namely (i) af+bg := 1 and (ii) hk := f-yg), so you won't be able to get a contradiction without doing something else.
Think of y as a constant (which is what it is). It might help to use a different letter, say \alpha, instead of y for the time being so you don't accidentally forget it's not a variable.
