Showing that multiplication by a complex number is a linear transform
8 replies · 4K views
Eclair_de_XII
"The set ##\mathbb{C}## of complex numbers can be canonically identified with the space ##\mathbb{R}^2## by treating each ##z=x+iy\in \mathbb{C}## as a column ##(x,y)^T\in \mathbb{R}^2##.
(a) "Treating ##\mathbb{C}## as a complex vector space, show that multiplication by ##\alpha=a+ib\in \mathbb{C}## is a linear transformation in ##\mathbb{C}##. What is the matrix?"
##(x+iy)(a+ib)=(xa-by)+i(ya+bx)##
If I had to guess what the complex matrix would look like, it would be:
##T(x+iy)=(xa-by)+i(ya+bx)=\begin{pmatrix}
a+bi & 0 \\
0 & -b+ai\end{pmatrix}\begin{pmatrix}
x \\
y \end{pmatrix}##
I'm not too sure on where everything goes; it's my first time fiddling with complex numbers, and moreover, using them in linear algebra.
Mmm... I think there's something wrong. ##\mathbb{C}## is a dimension 1 complex vector space. So of course, multiplication by ##\alpha## is a linear transformation, but it has no associated matrix (well, a matrix 1##\times##1 if you want). So I think the problem wants to show that multiplication by ##\alpha## is a linear transformation in ##\mathbb{R}^2##. In that case, the ##2\times 2## matrix must have only real numbers.
Eclair_de_XII said:
Problem Statement: "The set ##\mathbb{C}## of complex numbers can be canonically identified with the space ##\mathbb{R}^2## by treating each ##z=x+iy\in \mathbb{C}## as a column ##(x,y)^T\in \mathbb{R}^2##.
Relevant Equations: ##(x+iy)(a+ib)=(xa-by)+i(ya+bx)##
a+bi & 0 \\
x \\
y \end{pmatrix}##
The question perhaps wants you to present multiplication by ##\alpha## as a linear transformation on the real vector space ##\mathbb{R}^2##.
In this case, the set of complex numbers is represented by 2D vectors and also by a set of 2x2 real matrices.
A linear transformation doesn't have to be written as a matrix. A transformation, T, is linear if and only if T(u+ v)= Tu+ Tv and T(pv)= pT(v).
Let u= x+ iy and v= p+ iq. Then u+ v= (x+ p)+ i(y+ q). T(u+v)= (a+ bi)((x+p)+ i(y+q))= (a(x+ p)- b(y+ q))+ i(b(x+ p)+ a(y+ q))= (ax+ ap- by- bq)+ i(bx+ bq+ ay+ aq). And (a+ ib)(x+ iy)= (ax- by)+ i(ay+ bx) and (a+ ib)(p+ iq)= (ap- bq)+ i(aq+ bp). Adding those (a+ ib)(x+ iy)+ (a+ ib)(p+ iq)= (ax- by+ ap- ba)+ i(ay+ bx+ aq+ bp). Do you see that proves T(u+ v)= Tu+ Tv? (That is actually just saying that "multiplication distributes over addition in the complex numbers".) Similarly, if u= x+ iy then pu= px+ ipy. T(pu)= (a+ ib)(px+ ipy)= apx- bpy+ i(apy+ bpx)= p[ax- by+ i(ay+ bx)]= aT(u).
Welcome back! Great to see you here again!
Gaussian97 said:
Yes, but given a basis for the initial and final space, any (finite) linear transformation can be written as a matrix.
To be pretentious, there is an isomorphism between L(V,V) and nxn matrices once an ordered basis has been chosen. I am not sure of what "category" we are talking about, i.e., what kind of objects we're considering L(V,V) and all matrices.
Ultimately, using polar coordinates, you see that Complex multiplication is a composition of scaling and rotation, each being linear, so the composition is linear. This gives you a basis-free argument.
Represent u+iv in a matrix form as ## \begin{pmatrix} u & -v \\ v & u \end{pmatrix} ## Multiply two complex numbers as matrices and show that the result represents the desired complex number. Then you should be able to use matrix properties.
