Showing That the Modified Bessel Function of the First Kind is a Solution
The discussion focuses on demonstrating that the modified Bessel function of the first kind, I_v(x), is a solution to the modified Bessel equation. The user initially differentiates the function and substitutes it into the equation but expresses skepticism about the correctness of their results, particularly regarding a change of index. They encounter an issue with an undefined term when k=0, questioning whether it should be assumed to be zero. After further analysis, the user realizes an error in their index change, leading to a series that ultimately converges to zero. The conversation highlights the complexities involved in verifying solutions to differential equations using special functions.
womfalcs3
Hello,
I am in the process of showing that the modified Bessel function, I_v(x), is a solution to the modified Bessel equation,
x^2*y''+x*y'-(x^2+v^2)*y=0
I have differentiated the MBF twice and plugged it into show that the left hand side is in fact 0.
After a good amount of work, I've come to the following left hand side:
Where sigma=v.
Is that right? The math seems straight forward, and I only did one change of index that looks correct to me. I'm skeptical about the end result though.
Sorry, the actual left hand side I have are those two terms inside the sum multiplied by (x/2)^2k+v.
All inside the sum.
womfalcs3 said:
Hello,
Not sure either. But the second term is undefined when k=0 , i.e. (-1)! = Γ(0) is undefined. Or do we assume the second term to be zero?
Thank you for the response.
I just realized I made a mistake by changing the index, resulting in that denomintor. I eventually obtained a series that converged to 0.
Thank you again.
11K
