Showing the Fundamental Group of S^1 is isomorphic to the integers
The discussion centers on demonstrating that the fundamental group of the circle, denoted as π₁(S¹), is isomorphic to the integers, Z. The participants utilize the loop function fₙ defined by e²πins and aim to establish the relationship [fₙ][fₘ] = [fₘ₊ₙ]. The conversation highlights the importance of constructing a proper homotopy to show this equivalence, addressing specific issues in the initial attempts, such as ensuring continuity at s = 1/2 and maintaining the properties of loops. The final proposed homotopy successfully resolves these issues, affirming the isomorphism.
  • Understanding of algebraic topology concepts, particularly fundamental groups.
  • Familiarity with homotopy theory and its applications in topology.
  • Knowledge of complex exponentials and their geometric interpretations.
  • Experience with mathematical proofs and constructing homotopies in topological spaces.
  • Study the properties of fundamental groups in algebraic topology.
  • Learn about homotopy equivalences and their significance in topology.
  • Explore the concept of covering spaces and their relation to fundamental groups.
  • Investigate the implications of the isomorphism between π₁(S¹) and Z in various topological contexts.
Mathematicians, particularly those specializing in algebraic topology, students studying topology, and researchers interested in the properties of fundamental groups and homotopy theory.
trmukerji14
Hi,
I am reading J.P. May's book on "A Concise Course in Algebraic Topology" and have approached the calculation where \pi_{1}(S^{1})\congZ
He defines a loop f_{n} by e^{2\pi ins}
I want to show that [f_{n}][f_{m}]=[f_{m+n}]
I understand this as trying to find a homotopy between f_{n}*f_{m} and f_{m+n}
I have some attempts some attempts which have been unsuccessful are
H(s,t)= f_{n+mt}*f_{m(1-t)}
H(s,t)={e^{2\pi in2st}e^{2\pi im2s(1-t)} for s in [0,1/2]
{e^{2\pi im(2s-1)t}e^{2\pi in(2s-1)(1-t)} for s in [1/2,1]
Any help would be very much appreciated on my part.
Your idea seems correct. To separate into cases depending on whether s is smaller or larger than 1/2 is a good idea in this problem (as you have done).
However try to think about what you are doing. f_{m+n} loops with a speed of (m+n) for the whole interval [0,1]. f_n * f_m instead first loops with speed 2m for [0,1/2], and then loops with speed 2n for [1/2,1].
Let us first focus on what our homotopy should be for s \in [0, 1/2]. In this case we start with a speed of 2m and would like to end up with a speed of m+n. In other words for the part s\in[0,1/2] we would like to have
e^{2\pi i 2 m s}
when t = 0 and
e^{2\pi i (m+n) s}
when t = 1. In your case when we plug in t=0 we get
e^{2\pi i m 2s}
as we wanted, but when we plug in t=1 we get
e^{2\pi i n 2 s}
but we wanted
e^{2 \pi i (m+n) s}
Can you figure out how to correct this? The same problem happens when s \in [1/2,1], so you must also correct your homotopy here.
If you think you have done this, then all that remains is to check that this is a homotopy between the correct loops and that your two expressions agree on the intersection s = 1/2.
As a side remark the homotopy you constructed instead shows
[f_n][f_m] = [f_m][f_n]
which will follow from what you want to prove eventually, but it is also interesting if you couldn't figure out how to prove the general result.
Thank you for the help.
So far what I have is for s in [0, 1/2]
H(s,t)= e^{2\pi i(m+n)st}e^{2\pi im2s(1-t))}
and for s in [1/2, 1], I have:
H(s,t)= e^{2\pi i(m+n)st}e^{2\pi in(2s-1)(1-t))}
This satisfies our conditions for a homotopy for t=0 and for t=1.
Unfortunately, when we consider s it fails miserably. For a basepoint of 1. We have that H(0,t)=1 and that is good but when we try to plug in s=1/2 or s=1 we do not get what we want.
So I'm scratching my head at the moment trying to fix this.
As for the side remark, I understand that if we show this equivalence we can define a homomorphism from the integers to the fundamental group of the circle which will give us the abelian property. But I don't think I showed the abelian property with the homotopy I had since that one fails also when s=1.
Thanks for the help again.
There are basically still 3 issues with your homotopy:
1) You forgot an extra coefficient of 2 in front of n in your H for s >= 1/2.
2) It doesn't line up on s=1/2, i.e. the two expressions you gave are different when s=1/2
3) It isn't a homotopy of loops (i.e. not a based homotopy).
1 is easily fixable and I assume you can easily do this. If you solve 2, then 3 should be solved automatically since your speeds gives you whole revolutions (this is obviously not a rigorous argument and you will need to check, but intuition never hurts).
Fixing 1 for you I assume you wrote down:
H(s,t) = \begin{cases} e^{2\pi i (m+n) st}e^{2\pi i m 2 s (1-t)} &amp; \textrm{for }s \in [0,1/2] \\<br /> e^{2\pi i(m+n)st}e^{2\pi i n 2 (2s-1)(1-t)} &amp; \textrm{for }s \in [1/2,1]<br /> \end{cases}
Let us focus on fixing the fact that this is not well-defined for s=1/2. Ideally we would like some continuous function \alpha : [0,1] \to \mathbb{R} such that
H(s,t) = \begin{cases} e^{2\pi i (m+n) st}e^{2\pi i m 2 s (1-t)} &amp; \textrm{for }s \in [0,1/2] \\<br /> e^{2\pi i(m+n)st}e^{2\pi i n 2 (2s-1)(1-t)}e^{2\pi i \alpha(t)} &amp; \textrm{for }s \in [1/2,1]<br /> \end{cases}
would work as a homotopy. Note that this does not change the "speeds" we work with, but just where around the circle the second case takes over when s reaches 1/2, so as long as \alpha is well-chosen this should let us fix the problem at s=1/2. Clearly for this to work you must have (up to addition by an integer)
(m+n)\frac{1}{2}t + 2m\frac{1}{2}(1-t) = (m+n)\frac{1}{2} t + 2(1-t) + \alpha(t)
This should give you an expression for \alpha which will let you fix your homotopy, and then you should get a well-defined homotopy of loops.
I got it! This is awesome.
I got \alpha(t)=m(1-t) which gave the well defined homotopy
H(s,t) = \begin{cases} e^{2\pi i (m+n) st}e^{2\pi i m 2 s (1-t)} &amp; \textrm{for }s \in [0,1/2] \\<br /> e^{2\pi i(m+n)st}e^{2\pi i n 2 (2s-1)(1-t)}e^{2\pi i m(1-t)} &amp; \textrm{for }s \in [1/2,1]<br /> \end{cases}
This almost worked except when s=1, we did not get our desired result of 1. So if we use this:
H(s,t) = \begin{cases} e^{2\pi i (m+n) st}e^{2\pi i m 2 s (1-t)} &amp; \textrm{for }s \in [0,1/2] \\<br /> e^{2\pi i(m+n)st}e^{2\pi i n (2s-1)(1-t)}e^{2\pi i \alpha(t)} &amp; \textrm{for }s \in [1/2,1]<br /> \end{cases}
We have our homotopy of loops.
Thanks again for the help.I was really stuck out there.
  • · Replies 27 ·
  • · Replies 26 ·
