Deriving the Fourier Transform of the Signum Function and Proving its Properties
The discussion focuses on deriving the Fourier transform of the signum function and proving its properties. The Fourier transform is initially stated as S(ν) = 1/(jπν), and participants explore how to show that j2πνS(ν) equals 2 without directly deriving S(ν). The conversation highlights that S(0) should equal 0, despite an initial calculation suggesting it approaches infinity, emphasizing the need for a proper derivation. Ultimately, the Fourier transform of the derivative of the signum function leads to the conclusion that the Dirac delta function's contribution simplifies the expression, clarifying the result.
roam
The signum function is defined by$$sgn(t)=\left\{\begin{matrix}-1, \ t<0\\0, \ t=0 \\ 1, \ t>0 \end{matrix}\right.$$It has derivative$$\frac{d}{dt} sign(t) = 2 \delta(t)$$Use this result to show that ##j2\pi \nu S(\nu)=2,## and give an argument why ##S(0)=0.## Where ##S(\nu)## denotes the Fourier transform of the signum function
I know that the Fourier transform of the sign function is:$$S(\nu)=\frac{1}{j\pi \nu}.$$
If we substitute this into ##j2\pi \nu S(\nu),## we get ##2## as expected. But the question wants us to show this result without deriving an expression for the Fourier transform of ##sgn(t).## How can we do this?
Furthermore, if we substitute ##0## in ##S(\nu)## we get ##S(0)=1/j\pi (0) = \infty.## So what does the question mean by giving an argument that ##S(0)=0##?
If the F.T. of ## f(t) ## is ## F(\nu) ##, isn't F.T. ## f'(t)=j \nu F(\nu) ## ? (with possibly a factor of ## 2\pi ## depending on your definition of F.T. and your frequency variable.) And you can readily compute the F.T. of the delta function..I don't have a good answer for the S(0)=0 yet...editing...For S(0), it appears the function ## S(\nu) ## goes symmetrically from minus infinity to plus infinity near ## \nu=0 ##...
Don't trust a given formula for S(v) here. You can derive S(0) yourself, and the result should be zero.
How would you derive ##S(0)##? Did you use the sifting property ##S(0)=\int^\infty_{-\infty} \delta (t) \frac{1}{j \pi \nu} d\nu## or some other method?
Why not use ## S(\nu)=\int sgn(t)exp(-i 2\pi \nu t) dt ## and set ## \nu=0 ##. The function is odd so the integral is 0. See also my post #2.
Likes mfb and roam
So using the property ##\frac{d f(t)}{dt} \leftrightarrow j 2 \pi \nu F(\nu),## we will have:
$$2 \delta (t) = j 2 \pi \nu S(\nu).$$
But according to the question this should be equal to just ##2.## How do I make the Dirac delta disappear?
Simple: ## 2\pi j \nu S(\nu)=F.T.( 2 \delta(t)) ##. The F.T. of the delta function is 1.
Likes roam
Thank you, that makes perfect sense now.
Likes Charles Link
  • · Replies 17 ·
