Significant Figures Homework: Converting Time from Min to Hrs
The discussion focuses on converting time from minutes to hours while maintaining proper significant figures (SF). The conversion factor of 1 minute equals 1/60 hour is established as having infinite precision. When converting 20.0 minutes (3 SF) to hours, the result is 0.333 hours (3 SF), and the uncertainty is ±0.003 hours. It is confirmed that the answer should reflect the same number of decimal places as the uncertainty, ensuring clarity in scientific communication.
  • Understanding of significant figures (SF) in measurements
  • Knowledge of unit conversion principles
  • Familiarity with error propagation in calculations
  • Basic grasp of scientific notation and precision
  • Study the rules for significant figures in calculations
  • Learn about error propagation techniques in scientific measurements
  • Explore unit conversion methods and their implications on precision
  • Investigate the impact of significant figures on data representation in graphs
Students in physics or engineering, educators teaching measurement concepts, and anyone involved in scientific calculations requiring precision and clarity in reporting results.
Jam51
I am starting to confuse myself with the proper use of SF. I am to convert time from minutes to hours, keeping in mind proper SF
conversion factor: 1 min = 1/60 hr
The timing error is +/- 0.2 (1SF) = 0.003hr (1SF)
20.0 min (3 SF) = 0.333 hr (3 SF), but the conversion factor has 1 SF? would my answer be 0.3 hr? I'm confused because now I have varying decimal places and when I say 0.3 +/- 0.003 hr doesn't seem corect at all because when adding or subtracting I would drop the 0.003 therefore never being relevant?
Please help.
Conversion factors that are defined rather than measured are taken to have infinite precision. Thus the constant "60" in the conversion of minutes to hours or vice versa is exact.
Ok, so if I am converting 20.0 min using the "infinite" 60, the answer would reduce to the 3SF from the minute value?
Please help.
As a general rule, you need to quote your answer to the same number of decimal places as your uncertainty.
If you have an uncertainty of 0.55 on 10, I would expect to see ##x = (\mathrm{10.00} \pm \mathrm{0.55}) \mathrm{units}##
Right. Just so I am understanding that correctly.
In minutes my uncertainty is +/- 0.2, therefore on 20.0 minutes, it would remain as 20.0 +/- 0.2 min (both have the same amount of decimal places)
In hours the uncertainty would be +/- 0.003, where 20.0 min = 0.333 hr, would be 0.333 +/- 0.003 hr.
Now what if distance comes to play and it was only one decimal place? Am I still ok to leave the above as 3 decimal places if i intend to plot d v t on a graph?
As long as the different data is kept separate they keep their own significant figures and accuracy. So in a plot where the data are on separate axes they have their separate uncertainties and significant figures. If you use the data to calculate the slope of the resulting curve or the area under the curve, then you are "mixing" the data and you need to heed the significant figure rules for any results.
Thank you :smile:
