Simple AC circuit with L and parasitic R
  • Topic: Engineering
  • Thread starter Thread starter anthonuc
    Ac Ac circuit Circuit
4 replies · 4K views
anthonuc
[PLAIN]http://sphotos.ak.fbcdn.net/hphotos-ak-snc4/hs894.snc4/72731_10150110340044992_712009991_7710053_709779_n.jpg
The circuit has a non-ideal inductor with parasitic R. v0(t) goes to coswt as the limit of w goes to zero.
The output signal has a +15 degree phase shift at 50kHz.
Determine L
arctan(z1)-arctan(z2)=arctan[(z1-z2)/(1+z1z2)]
V0(t)= Xa * |H| * cos(wt+angle H)
H = a+bj
angle H = arctan(b/a)
I change the impedances to 50 for the resistor and jwL for the inductor. Then using voltage division I get Vo = Vi(jwL/(jwL+50)) where (jwL/(jwL+50)) = H
However when trying to get the angle of H i get arctan(wL/0)-arctan(wL/50) and the arctan identity formula doesn't seem to help as the first value just goes to pi/2. Can I set the angle to 15 degrees and use w = 2pi*f where f =50khz to solve for L?
Trying this I get L = 5.9e-4 Henrys. Does this seem right? Feels low.
I don't know what to make of the first hint either with the limit of w going to zero.
Thanks if you read/help, much appreciated.
I don't know what all those equations are for. Impedances in series add. Ztotal = ZR + ZL.
Use the complex equivalent of V=IR: V=IZ, or V(t)=I(t)Ztotal
V(t) = 2cos(wt)
Now you can find the current through the series circuit using V(t)=I(t)Ztotal. This is also the current through the inductor.
Next, apply V=IZ again to find the voltage across the inductor. This time V=Vinductor and Z=iwL. Vinductor will have a different phase from the voltage source. This phase difference is what you are after.
Hmm. Well in class we were taught to use sinusoidal steady states to solve these problems which is where the relevant equations came from.
Using your method I get I=IL=(jwL+50)/(2costwt)
Then solving for VL in V=IZ I get
VL = (-w2L2+50jwL) / 2coswt
However I'm not sure what to do with this. This has a different phase from the voltage source?
[PLAIN]http://dl.dropbox.com/u/4222062/L-R.PNG
You are asked to work out the inductance, so you can work it out from the above diagram.
Thanks for the help but I've managed to solve it correctly.
You use sinusoidal steady state to find the parasitic R in the inductor. The R attached in the circuit is not the parasitic R. It's just a regular resistor. There's also some unknown parasitic resistance in the non-ideal inductor.
Parasitic R = Rp
You use Vo = 2coswt*(jwl + Rp) / (jwl + Rp + 50).
Set this equation equal to coswt as w goes to zero and you'll get Rp = 50.
Knowing this value you can plug it back into this equation:
and use H = (jwl + Rp) / (jwl + Rp + 50)
the angle of H = 15 degrees when f = 50Khz where w=2pi*f
the angle of H = arctan(50/(100000*pi*L) - arctan(100/100000*pi*L) = 15 degrees
Then you can use the identity
and get a solvable equation for L. You get a quadratic polynomial but it should be easy enough to solve in the end.
I ended up with L = 85mH
Actually I still have to find out what the correct answer will be since my quadratic actually gives me negative roots.
Hope this can be help for future references at least! I appreciate your guys' help.
