Simple Algebra Division question
  • Thread starter Thread starter DeepGround
    Algebra Division
The discussion centers on the ambiguity of multiple divisions in algebra, particularly when expressed without parentheses. Participants clarify that expressions like a/b/c can lead to confusion, as they can represent different operations depending on their grouping. It is emphasized that using parentheses is crucial for clarity, as it dictates the order of operations. The conversation also touches on the interpretation of fractions and the impact of dividing by 1, which doesn't change the value but can complicate notation. Ultimately, the consensus is that proper notation is essential to avoid misinterpretation in mathematical expressions.
DeepGround
Hello,
I am not grasping how to deal with multiple divisions properly.
If I have a/1 divided by b/1 divided by c/1
How do I know if the compressed form is ac/b or a/bc?
Mathematics news on Phys.org
It's simple: you don't.
a/bc
What poster #2 is saying, is that (a/b)/c is not equal to a/(b/c). So talking about a/b/c, without properly using parenthesis to tell which of the two cases is meant, is simply ambiguous.
i would have chosen a/(bc) as what was meant, but i see the problem.
Is it ever possible to be working on a problem and end up with a\b\c?
a/b/c are just written-down symbols that stand for an idea on your mind; if you work on a problem and get that result, in your mind you'll know what you mean (if you're not insane). Now, other people won't understand you unless you use parenthesis, or write something more graphical like \frac {a/b}{c} or \frac {a}{b/c}.
I think what this problem is lacking is parentheses! ( )
DeepGround said:
Hello,
Is a/1= a, b/1= b, c/1= c? If so why write it that way?
What does "\" mean here?
To specify that all variables are already a fraction. Some math texts show a/b/1 is a/b and a/1/b is ab/1
I meant / by "\"
a/b/1 can be interpreted as (a/b)/1= a/b or a/(b/1)= a/b so that's not a problem. a/1/b could be interpreted as (a/1)/b= a/b or a/(1/b)= ab. That's a problem.
It really doesn't matter whether a or b are "already" fractions.
I meant / by "\"
Oh wow, I just figured out where I went wrong, now I see how it does not matter where the main division is located because the if all denominators are 1 then it doesn't matter if you multiply the 1 by the numberator or the denominator.
I thought the general rule for an ambiguous case was to work from left to right and which would be ((a/1)/(b/1))/(c/1) = a/bc.
