Simple bucket lifting problem statics/physics
  • Thread starter frank1234
    Lifting
frank1234
A worker is trying to lift a 100lb bucket. Assume that the bucket is in static equilibrium as it is raised from 2ft to 18ft. Find the tension in the rope as a function of y.
I solved for angle, a, which cam out to be: arctan(4/(20-y))
Then I solved for the x and y components of the tension vector using: T_x=50lb(a+90) and T_y=50lb(a+90)
I divided the weight by 2 because there are 2 ropes
Then I solved for tension with: sqrt(T_x^2+T_y^2)
The problem I am seeing is that the tension is constant at 30lb no matter the angle, a. I do not think that this should be the case. Could somebody point out where I went wrong? Thank you!
  • Diagram of a pulley-and-rope setup: a rope runs over pulleys at A and C with a point B between them, with a 4 ft horizontal gap marked, a 20 ft height marked, angle a, height y, and a stick figure pulling the rope on the right over green ground.
T_y=50lb(a+90) is wrong. Have another think.
