Natural Gas Consumption Calculation in Cubic Feet and Seconds
  • Thread starter Thread starter Mivz18
    Calculation
The empirical equation for natural gas consumption, V=1.50t + 0.80000(t^2), where V is in millions of cubic feet and t is in months, needs conversion to cubic feet and seconds. The conversion from months to seconds involves multiplying by 2.592E6 seconds per month. The correct coefficients should include units: the first coefficient should be in cubic feet per second and the second in cubic feet per second squared. The calculations indicate that the original approach was correct, but the omission of units in the final equation caused confusion. Proper unit assignment is crucial for clarity in such calculations.
Mivz18
Problem: The consumption of natural gas by a company satisfies the empirical equation V=1.50t + 0.800 00(t squared), where V is the volume in millions of cubic feet and t the time in months. Express this equation in units of cubic feet and seconds. Assign proper units to the coefficients. Assume a month is equal to 30.0 days.
My work:
From the equation given, I took each part of the right and converted the months variable to seconds.
1.50(t months) * (t 30 days) * (t 24 hours) * (t 60 min) * (t 60 sec.)
1 (t month) (t 1 day) (t 1 hr.) (t 1 min)
= 3.888E6(t sec.)
Then I repeated the conversion multiplication fractions with 0.008 00 and squaring the other numbers and reaching a value of 5.37477E9(t sec)^2
My new equation is then V= 3.888E6(t sec.) + 5.37477E9(t sec.)^2
dividing by a million to convert millions of cubic feet to cubic feet, I get:
V=3.889E6(t sec.) + 53747.7(t sec.)^2
However, the book gives an answer of 0.579t (ft cubed/sec.) + 1.19E-9t^2 (ft cubed/sec. squared)
Is not assigning units to the coefficients screwing me up or is there another problem with my calculations?
My work:
= 3.888E6(t sec.)
Remember that the given formula requires t (the time in months). When dealing with t you have to be careful... I'd do it like this:
let a=time in seconds.
a = t months * (30days/1 month) * (24 hours/1day)*(60min/1hr)*(60s/1min)
so a= 2.592E6 * t seconds
So now solve for t, and then plug back into the original equation.
So t=a/2.592E6 . Plug a/2.592E6 into the original equation. Think of it like this. You've got the time in seconds a, then getting the time in months t, in terms of a...
So you'll then get an equation in terms of a, where a is in seconds. Volume is still in millions of cubic feet.
To get from millions of cubic feet to cubic feet, you need to multiply by a million, not divide.
Likes MarianC
Your calculations seem to be correct, however, you did not assign units to the coefficients in your final equation. This can lead to confusion and difficulty in understanding the units of the equation. The units of the first coefficient should be (ft^3/sec) and the units of the second coefficient should be (ft^3/sec^2). It is important to always include units in your calculations to avoid any confusion or errors.
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
12K
