Simple Circuit diagram Question
  • Thread starter Thread starter skykiller95
    Circuit Diagram
11 replies · 4K views
skykiller95
The diagram shows identical lamps X and Y connected in series with a battery. The lamps light with normal brightness. A third lamp Z is connected in parallel with lamp X.
What happens to the brightness of lamp Y?
A) Brighter than normal
B) Normal
C) Dimmer than normal
D) Very dim (cannot be seen)
I'm completely clueless about it and slightly confused. Any help would be appreciated.
Think of it in terms of resistors - is there a difference in total resistance between the first situation and the second?
What do you think happens? Hint: See if you can figure out how the current passing through lamp Y changes (if it does).
Hmms, I would have to say, yes?
Hmm, wouldn't the additional lamp added in parallel alter the current in the entire circuit?
Yes, so what happens to the current going through lamp Y? Increase, decrease, or remain the same?
I'm not so sure, but I would say increase.
Guessing doesn't count.
Take daveb's hint: The lamps are like resistors. What happens to the total resistance and thus to the current?
Total resistance decreases, current increases.
Doc Al said:
Good!
Oh so the bulb is brighter?
Thanks for helping guys!
Right.
Adding that resistor in parallel with X drops the total resistance, which increases the current flowing through Y. More current means a brighter bulb.
