What Is the Efficiency of a Monoatomic Ideal Gas Cycle?
  • Thread starter Thread starter diegzumillo
    Efficiency
The discussion revolves around calculating the efficiency of a monoatomic ideal gas cycle, with initial parameters provided from a 2008 admission test. The user initially miscalculated the efficiency, assuming the area under the curve represented heat absorbed, leading to confusion about the correct values for work done and heat transfer. After clarifying the relationships between work, heat, and internal energy, the user correctly calculated the heat for each path in the cycle and determined the efficiency to be approximately 13.6%. The conversation highlights the importance of understanding thermodynamic principles and accurately applying them to solve problems. The final solution emphasizes the correct use of equations and the significance of each cycle's path in determining overall efficiency.
diegzumillo
Hello again, all! I have another basic thermodynamics question :P This one came from a 2008 admission test. Seems simple enough, but as usual, my answer doesn't match =P
A monoatomic ideal gas performs, reversibly, the cycle shown in the diagram attached in this post. The values of P_0 and V_0 are, respectively, 1\times 10^5 Pa and 100cm^3. The area of the interior of the cycle is 15J. What is the efficiency of this cycle?
e=\frac{W}{Q_h}
e is the efficiency, W is work done by the system and Q_h is the energy absorbed by the system (heat).
This is probably the only equation relevant here..
The problem seemed straigh forward: The area enclosed by the cycle is the work done. The area under the curve ab is the Q_h, right? If so, calculating this is trivial and results in an efficiency of, approximately, 0,43.
However, this is not right. The correct answer should be 0,136.
No ideas? :P
Ah, no. That area would be the work done from a to b.
Q is T dS, and W is P dV.
The easiest way to get Q, for any single path of this cycle, is to use
ΔU = Q - W
since ΔU and W are fairly straightforward to calculate.
Redbelly you are smart!
Thanks Redbelly :) I got carried away by the relation W=Q_h-Q_c and assumed something wrong :P
Can I classify this system as cyclic? If so, isn't the internal energy variation supposed to be zero?
Gosh, thank you.
Yes, the entire process is cyclic, and ΔU is zero for the entire cycle.
But ... to calculate Qh, you'll need to consider each individual subpath, and whether heat is flowing into or out of the system for that path. Heat in contributes to Qh, while heat out does not.
Since ΔU is not necessarily zero for each subpath, it needs to be considered.
Hello again! I let go of this problems for a few days. But today I took another look at it, and I think I have a solution :)
We'll use this equation for heat
Q=C\Delta T
where this C depends on the path.
We can start by calculating the heat for the path BC and CA, we'll call them Q_{bc} and Q_{ca}, respectively. We cannot calculate directly Q_{ab} because we only know c_p=3/2 R, for constant pressure, and c_v=5/2 R, for constant volume. So we have
Q_{bc}=\frac{c_v}{R}(P_c V_c - P_b V_b)=-45J
Q_{ca}=\frac{c_p}{R}(P_a V_a - P_c V_c)=-50J
(I'm calling P_i and V_i for better understanding)
We can see that both of those values represent heat leaving the system. Now we'll use the internal energy relations to find Q_{ab}. The internal energy relations for each path are:
\Delta U_{bc}=Q_{bc}-W_{bc} (Yes, W_{bc} is zero)
\Delta U_{ca}=Q_{ca}-W_{ca}
Since we know that
\Delta U=\Delta U_{ab}+\Delta U_{bc}+\Delta U_{ca}=0
and
\Delta U_{ab}=A_{ab}-W_{ab}
We have
Q_{ab}=W_{ab}-(Q_{bc}-W_{bc}+Q_{ca}-W_{ca})
Q_{ab}=W-(Q_{bc}+Q_{ca})=110J
Wich is our heat transferred into the system! (Q_h)
In possession of these values, we can now calculate the efficiency of this cycle:
e=\frac{W}{Q_h}=13,6%
=D
(Btw, for some strange reason, I can't visualize correctly the formulas. So there may be some errors. I'll correct them as soon as I'm able to read what I wrote :P)
Latex equations have been having problems for several days now.
Much of what you wrote can be done without Latex. You can get the Greek letter Δ here:
https://www.physicsforums.com/blog.php?b=347
Also:
[noparse]a[/noparse] for subscript a
[noparse]2[/noparse] for superscript 2
Yep.. just saw the anouncement. What a bummer!
Since there is no estimate for the return, I'll post the solution again! (But I'll keep that one there... it took me a while to do! :P)
The solution again. Simplified notation version :D
Q=CΔT
We can start by calculating the heat for the path BC and CA, we'll call them Qbc and Qca, respectively. We cannot calculate directly Qab because we only know cp=3/2 R, for constant pressure, and cv=5/2 R constant volume. So we have
Qbc=cv/R (PcVc-PbVb)=-45J
Qca=cp/R (PaVa-PcVc)=-50J
(I'm calling Pi and Vi for better understanding before using the values given by P0 and V0)
We can see that both of those values represent heat leaving the system. Now we'll use the internal energy relations to find Qab. The internal energy relations for each path are:
ΔUbc=Qbc-Wbc (Yes, Wbc is zero)
ΔUca=Qca-Wca
Since we know that
ΔU=ΔUab+ΔUbc+ΔUca=0
and
ΔUab=Qab-Wab
We have
Qab=Wab-(Qbc-Wbc+Qca-Wca)
Qab=W - (Qbc+Qca) = 110J
Wich is our heat transferred into the system! (Qh)
e=W/Qh=13,6%
=D
Thanks again Redbelly! And btw, that's a really helpful list of symbols! :) Especially for this dark times without latex.. lol
Diego Floor said:
... cp=3/2 R, for constant pressure, and cv=5/2 R constant volume.
It looks like the values of cv and cp have been swapped here, but you did use the correct values in the calculation. Good job, you nailed this one!
You're welcome. "Dark times", LOL
  • · Replies 32 ·
  • · Replies 23 ·
12K
