Simple Harmonic Motion of a wave
In summary, the problem involves a cheerleader performing simple harmonic motion with an amplitude of 18.0 cm and a frequency of 0.850 Hz. Part (a) requires finding the maximum magnitude of acceleration and velocity. Part (b) involves finding the acceleration and speed at a specific coordinate. Part (c) asks for the time required to move from the equilibrium position to a point 12.0 cm away. Part (d) discusses the use of the energy approach in solving these quantities, with part (a) being solvable through conservation of energy while parts (b) and (c) cannot be solved using this method due to the absence of the time variable.
iwonde
31
[SOLVED] Simple Harmonic Motion
A cheerleader waves her pom-pom in simple harmonic motion with an amplitude of 18.0 cm and a frequency of 0.850 Hz. Find (a) the maximum magnitude of the acceleration and of the velocity; (b) the acceleration and speed when the pom-pom's coordinate is x = +9.0 cm; (c) the time required to move from the equilibrium position directly to a point 12.0 cm away. (d) Which of the quantities asked for in parts (a), (b), and (c) can be found using the energy approach, and which ones cannot? Explain.
abs(a_max)= ω^2A, A = amplitude
abs(v_max)=ωA
ω=2πf, f=frequency
a = -ω^2 sqrt(A^2 - x^2)
(a) ω=2π(0.85)= 5.34 rad/s
abs(a_max)= (5.34)^2(0.18)= 5.13m/s^2
abs(v_max)= (5.34)(0.18) = 0.961 m/s
(b) a = -(5.34)^2 sqrt((0.18)^2 - (0.09)^2) = -4.45m/s^2
speed = abs(v) = (5.34) sqrt((0.18)^2 - (0.09)^2) = 0.832 m/s
I don't know how to approach (c) and (d).
Maybe this will do for the (c) part:
[tex]x=As in\omega t[/tex].
(d) part seems easy. Just try calculating every part using the law of conservation:
[tex]E=E_{k}+E_{p}=E_{k(max)}=E_{p(max)}[/tex].
for d) I'm thinking that part (a) can be found by using the energy approach because K_max = (1/2)m(v_max)^2, from v_max, you can find a_max; part (b) cannot be found by using the energy method because energy doesn't deal with what happens in the beginning and end; part (c) cannot be found using the energy approach because the time variable doesn't occur in the energy equations.
Is that right?
The velocity can be found at any given point through conservation of energy.
I'm still a little confused about the energy approach in part (d).
1. What is simple harmonic motion of a wave?
Simple harmonic motion of a wave is a type of oscillatory motion in which the displacement of a particle or wave is directly proportional to the force acting on it and is in the opposite direction of the force. This results in a periodic motion with a constant amplitude and frequency.
2. What are the factors that determine the simple harmonic motion of a wave?
The factors that determine the simple harmonic motion of a wave include the mass and elasticity of the medium in which the wave is traveling, as well as the frequency and amplitude of the wave itself.
3. How is the frequency of a simple harmonic wave calculated?
The frequency of a simple harmonic wave is calculated by dividing the speed of the wave by its wavelength. The speed of a wave can be calculated by multiplying its wavelength by its frequency.
4. What is the relationship between simple harmonic motion and energy?
Simple harmonic motion is directly related to energy, as the energy of a wave is directly proportional to its amplitude squared. This means that as the amplitude of a wave increases, so does its energy.
5. How does damping affect simple harmonic motion of a wave?
Damping, or the gradual decrease in amplitude of a wave, affects simple harmonic motion by decreasing the energy and frequency of the wave over time. This can be caused by external factors such as friction or air resistance.
