Simple Harmonic Motion of an air-track glider
The forum discussion centers on the calculations related to Simple Harmonic Motion (SHM) involving an air-track glider and various oscillating systems. Key topics include determining the position of an air-track glider at a specific time, calculating phase constants, and finding spring constants based on oscillation periods. Users encountered errors in their calculations, often due to incorrect use of units or misapplication of formulas. The community provided corrective feedback, emphasizing the importance of using the correct mode on calculators and ensuring accurate rearrangement of equations.
  • Understanding of Simple Harmonic Motion principles
  • Familiarity with angular frequency and its calculations
  • Proficiency in using trigonometric functions for SHM
  • Knowledge of spring constants and their relationship to mass and period
  • Study the derivation and application of the SHM equations, particularly X(t) = A cos(ωt)
  • Learn how to calculate phase constants in SHM using initial conditions
  • Explore the relationship between mass, spring constant, and oscillation period in detail
  • Practice solving SHM problems with varying initial conditions and parameters
Students studying physics, particularly those focusing on mechanics and oscillations, as well as educators and tutors looking to clarify concepts related to Simple Harmonic Motion.
saralsaigh
I have several questions i will write all of them and give you my attempt at a solution, hope you can help me figure out what i am doing wrong, Thanks.
Question 1:
An air-track glider is attached to a spring. The glider is pulled to the right and released from rest at t=0.00 s. It then oscillates with a period of 11.4 s and a maximum speed of 52.9 cm/s. What is the glider's position at t=0.561 s?
==> ANSWER:
T = 11.4s, Vmax = 52.9 cm/s
I found out W (angular frequency) to = 0.175 pi = 0.55498 rad/s
I also found A = 96.22 cm I used the equation
X(t) = A cos ( w t )
X(0.561) = (96.22) cos ( 0.55498 x 0.561 )
= 96.2186 cm
apparently this is the wrong answer...idk wat i am doing wrong though..any pointers?
Question 2:
A 543.0 g mass oscillates with an amplitude of 12.4 cm on a spring whose spring constant is 27.3 N/m. At t=0.00 s the mass is 4.36 cm to the right of the equilibrium position and moving to the right. Determine the phase constant. Use a cosine function to describe the simple harmonic motion.
==> ANSWER:
Knowns: Xinitial = 4.36 cm A= 12.4 cm
phase constant = cos^-1 ( Xinitial / A )
= cos^-1 (4.36 / 12.4)
= 69.41 rad...i think the units are radian rite?
Again i got the wrong answer and idk where i went wrong...
Question 3:
An object in simple harmonic motion oscillates with a period of 4.00 s and an amplitude of 9.79 cm. How long does the object take to move from x=0.00 cm to x=6.50 cm?
==> ANSWER:
Knowns: T=4s A= 9.78m
I found: w= 2pi/ T = 0.3927 rad/s
Vmax = wA = 3.845 cm/s
i have no idea how else to go about this question...any suggestions?
Question 4:
The velocity of an object in simple harmonic motion is given by v(t)= -(0.226 m/s)sin(15.0t + 2.00π), where t is in seconds. What is the first time after t=0.00 s at which the velocity is -0.110 m/s?
==> ANSWER: so since the equation for velocity is
V(t) = -(Vmax) sin ( wt + phase constant )
we know that,
Vmax = 0.226m/s W= 15 rad/s phase constant= 2pi rad
i figured that the speed would be the same after a period...so i set out to find the period,
T = 2pi / w = 0.4189s
however that is the wrong answer, is there a flaw in my logic?
Question 5:
A 6.00 g spider is dangling at the end of a silk thread. You can make the spider bounce up and down on the thread by tapping lightly on his feet with a pencil. You soon discover that you can give the spider the largest amplitude on his little bungee cord if you tap exactly once every 7.00 s seconds. What is the spring constant of the silk thread.
==> ANSWER:
m= 6g = 0.006 kg
T= 7s
k = ?
I used the equation T = 2pi ( m / k )^(1/2)
i rearranged it for k = (m 4pi) / T^2 = 1.54 x 10^-3 N/m
again this was the wrong answer...please help.
Sry for posting so many questions but i didnt want to start many threads and the topic is all related its just that I am studying for a test and these are the questions I am stuck on...any help would be greatly appreciated..THANKS AGAIN!
1.The physics part seems to be correct.However I'm getting something like 91 as the answer.if that is close to the correct answer you need to check your calculations,put exact value of pi and stuff.
2.Your calculator is not in radian mode.
3.you know x as a function of t.so you can write t as a function of x.take it from there.
4.Are you sure you have got the equation correct?anyways have you tried using the formula directly?
5.You made a mistake while rearranging.check it.
1- yea i wasnt in radian mode ...THANKS
2- I tried it in radian and i got 1.212 and its also wrong :S
3- i can rearrange the x(t) equation to have it as a function of t but i have two x's...im confused...
4- yea i believe its the rite equation and i did try it and i got the same answer
5- i couldn't find my mistake so i just plugged in the numbers and then rearranged and i still got the same answer :/
2.how can that be wrong??i'm stumped.
3.how would you do it if you were to calculate the distance traveled b/w say,t=1 and t=2?think a bit and I'm sure you'll find a way.
4.the same answer??what you've found there is just the time period of the shm.
remember that a 2pi phase change gives the same value of sine function.i'm getting a much lower value - less than 1/10th of your value.is that correct?
5.yet there is a mistake.something you didn't square...
  • · Replies 18 ·
