Simple harmonic motion/static equilibrium -spring problem, mass given
mariegrdnr
A 0.500 kg mass is suspended from a spring and set into
oscillatory motion. A motion detector is used to record the motion, and it is found that its velocity function is given by Vx(t) What are:
a. the period of the motion;
b. the amplitude;
c. the maximum acceleration of the mass; and
d. the force constant of the spring?
given
Vx(t)=-ωAsin(ωt+[itex]\phi[/itex])
not given but seems like the way I need to head
Fspring=-k[itex]\Delta[/itex]y
T=2pi[itex]\sqrt{m/k}[/itex]
Did FBD where Fspring=-k[itex]\Delta[/itex]y is straight up and weight=4.9N goes straight down. Giving Fnety=
K[itex]\Delta[/itex]L-mg=0
K[itex]\Delta[/itex]L=mg? can I make this assumption or am I missing something?
Also I have three unknowns k,[itex]\Delta[/itex]L, T and can't find another equation to substitute into for third variable. I just need to know if I am heading in the right direction for this problem.
Yes I agree, but none was given, so I was hoping that someone might see something:-(
Thank you for taking a look!
No, I believe it can be solved with the given info, provided that the mass was set in motion in the usual way by imparting an initial displacement to the system at rest.
Hint: determine x(t) and dx/dt as functions of time. Determine maximum dx/dt. Then determine time t1 at which dx/dt is half of max. This I believe allows solving for every parameter.
