Integrating v^-2 and Comparing Solutions for vi to v and t to 0
  • Thread starter Thread starter atypical
    Integrating
The integral from vi to v of v^-2dv results in -1/v + 1/vi, not just a constant C, due to the evaluation of the definite integral. The comparison with the equation -3t indicates that the integration limits must be applied correctly. The confusion arises from the misunderstanding of the constant of integration in definite integrals. The correct interpretation shows that the book's solution includes the term 1/vi, which accounts for the initial condition at vi. Understanding the limits of integration clarifies the discrepancy in results.
atypical
The integral from v=vi to v of v^-2dv = -3 integral from t=0 to t of dt
I am getting -1/v + C=-3t and the book is getting -1/v+1/vi=-3t. Not quite sure where they are getting 1/vi as I am getting C.
Your integral is from vi to v, so you can't really get C.
your integral on the left works out as
\left[ \frac{-1}{v} \right] _{v_i} ^{v} = \frac{-1}{v}- \left( -\frac{-1}{v_i}\right)
  • · Replies 20 ·
  • · Replies 27 ·
