Simple Newton's 2nd Law problem Why isn't this answer right, though?
10 replies · 2K views
Lo.Lee.Ta.
1. "A 40.0-kg crate is pulled along a horizontal floor by the ideal arrangement
shown in figure below. The force F is 280 N. The coefficient of kinetic friction between the crate and the floor is 0.170. What is the acceleration of the crate?"
______box---^=Pulley__
Okay, this is a weird drawing of the situation. Just a box on a flat surface.
It's attached by a string to a pulley and the other end of the string is anchored to a
cone (^).
So I thought the solution is just this:
εF(y) = ma(y)
-w + N = ma(y)
-392 + N = (40)(0)
N= 392N
εF(x) = ma(x)
-f + F = ma(x)
[mu(k)](N) + 280 = (40)(a)
(.17)(-392) + 280 = (40)(a)
a= 5.33m/s^2
BUT, this is not the right answer on my test!
The right answer is 1.83m/s^2.
How do you get that answer?
Thank you so much! :D
Can you post the diagram? It's not clear what the arrangement is.
Okay, this is it.
Okay. If the pulley is massless, how is the tension in the cord related to the force F?
(a) Tension = F
(b) Tension = F/2
Lo.Lee.Ta. said:
Okay, this is it.
Good. So now figure out the tension in the rope. That will tell you the force on the crate.
Um, okay...
So I looked up the formula for tension in a rope.
They say it's: F(tens.) = ma - (mu)(-mg)
To find the a, I did: F = ma
280 = (40)(a)
a = 7m/s^2
So, that means it's: F(tens.) = (40)(7) - (.17)(-392)
F(tension) = 346.64N
So, then I thought I would use the tension force instead of the F...
-f + T = ma(x)
-392 + 346.64 = (40)(a)
a = -1.134m/s^2 BUT THIS IS NOT RIGHT...
It's negative. I don't really know what's wrong. I'm thinking the F(tension) is wrong... =_=
To find the tension in the rope analyze the forces acting on that massless pulley.
It seems to me that the tension would be equal to the force, F.
Pulley:
ƩF(x) = ma(x)
-T + 280 = (0)(a)
T = 280
So I still don't see why the Tension isn't the same thing as the Force F...
Box:
ƩF(x) = ma(x)
-f + T = ma(x)
(.17)(-392) + 280 = 40(a)
a = 5.334m/s^2... The same wrong answer... Is there some force on the Pulley I'm leaving out?!
It is massless, so there would be no N force or weight.
If you look at the pulley, then you have two tension forces acting to the left.
So, 2T = F
→ T = 140N
WOOO! Hallelujah!
Thanks, ap123! I've been working on this problem FOR-EVER!
But what the heck?!
2 tensions?
Is this because of the tension where the string attaches to the box AND where the string from the pulley attaches to the cone?
-Both are pointing in the left direction.
Yes.
