Simple problem about borel and measurable sets
  • Thread starter Thread starter hellbike
    Measurable Sets
The discussion focuses on proving the equality Y(x(B)) = xY(B) for every Borel set B and x > 0, where Y represents the Lebesgue measure. Participants clarify that Borel sets can be approximated using open intervals, and the Borel σ-algebra is defined as the smallest σ-algebra containing all open intervals. The conversation also establishes that measurable sets are a completion of the measure defined on Borel sets, and each measurable set can be expressed as a union of a Borel set and a set of outer measure zero.
  • Understanding of Borel sets and their properties
  • Familiarity with Lebesgue measure and its definitions
  • Knowledge of σ-algebras and their characteristics
  • Basic concepts of measure theory, including outer measure
  • Study the properties of Borel σ-algebras in detail
  • Learn about Lebesgue measure and its applications in real analysis
  • Explore the concept of measurable sets and their relationship to Borel sets
  • Investigate the proof techniques for establishing properties of measures
Mathematicians, students of real analysis, and anyone interested in measure theory and the properties of Borel and measurable sets.
hellbike
Show, that Y(x(B)) = xY(B) (Y is Lebesgue_measure ) for every borel set B and x>0.
Show that also for measurable sets.
I don't know how to prove anything for neither borelian or measurable sets, so I'm asking someone for doing this problem, so i can do other problems with borelian and measurable sets by my own.
The method is always thesame: consider
\{A\subseteq \mathbb{R}~\vert~Y(xA)=xY(A)\}
and show that this is a \sigma-algebra that contains the open intervals...
and this is for both, borel and measurable?
Is showing that this is true for approximation using open intervals is enough for proving this for borel sets?
because borel sets are these that can be approximated using open intervals, right?
And what are measurable sets?
Intervals are enough for Borel sets because Borel \sigma-algebra is by definition the smallest one containing all the intervals. You still need to prove that this set is \sigma-algebra.
Borel sets are enough for measurable sets, because it's a completion of measure defined on Borel sets. Each measurable set is a union of a Borel set and set F of (outer) measure 0. Set of outer measure 0 is contained in Borel set E of measure 0, and so by the previous part, xE is of measure 0. Hence, xF also has outer measure 0.
I'm not sure if i understand this, because this seems too easy.
It's obvious that Y(x(B)) = xY(B) is true for every interval.
It's obvious that this set is closed under countable sums from definition of measure (this just requires construction of pair disjoint sets).
A\B for every A,B from R is also obvious from Y(A\BnA) = Y(A) - Y(BnA)
And that's it?
It seems fine to me.
