Simple projectile motion question
The discussion revolves around calculating the height of a missile fired vertically with an initial velocity of 20 m/s and an acceleration defined by dv/dt = -10 + t/2 m/s². The user attempts to derive the height after two and four seconds but struggles with the integration process. A response clarifies the integration steps needed to find velocity and subsequently displacement, emphasizing the importance of correctly applying calculus. The user is encouraged to follow through with the integration to solve for height and direction at t = 4 seconds. The conversation highlights common challenges in applying calculus to physics problems.
ashclouded
A missle is fired vertically up from a ground with an initial velocity of 20m/s. The acceleration at any time is given by dv/dt = -10 + t/2 m/s^2.
Find the height of the missile after two seconds
Find the height after four seconds
the direction the missile is traveling when t = 4
Displacement = x
Velocity = dx/dt
acceleration = dv/dt
dx/dt = -10t + t^2/4 + c
found c to be 20
x = -5t + x^3/12 + 20t + c
when t = 0 displacement = 0
c = 0
-5t + x^3/12 + 20t
then I don't know what to do
Displacement = x
Velocity = dx/dt
found c to be 20
c = 0
-5t + x^3/12 + 20t
You've managed to mangle your calculus here, which is why you get confused.
According to the OP, dv/dt = -10 + t/2 m/s2
If you separate the variables and integrate, you get
∫ dv = ∫ (t/2 - 10) dt, or
v = t2/4 - 10t + C m/s
According to the OP, v @ t = 0 is equal to 20 m/s, so C = 20
But, v = dx/dt = t2/4 - 10t + 20, so separating variables and integrating again we get:
∫ dx = ∫ [ t2/4 - 10t + 20] dt which gives
which I'll leave you to work out. You should be able to answer the questions about the height of the rocket very easily.
Sorry about the multiple post, thanks for the help but
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 23 ·
  • · Replies 22 ·
