Why Does Spin Down Have Lower Energy Than Spin Up in a Magnetic Field?
The discussion clarifies that in a magnetic field, the energy of a spin-1/2 particle's states is determined by its alignment with the field. The Hamiltonian for the system is given by $$\hat{H}=\frac{\hbar\omega}{2}\sigma_z$$, where the energy of the spin-up state $$\ket{up}$$ is $$\frac{\hbar\omega}{2}$$ and the energy of the spin-down state $$\ket{down}$$ is $$-\frac{\hbar\omega}{2}$$. The negative energy for the spin-down state arises from its alignment opposite to the magnetic field, which is directed along the positive z-axis. Including the complete Hamiltonian, including the magnetic moment and the magnetic field strength $$B_0$$, is essential for accurate energy calculations.
  • Understanding of quantum mechanics, specifically spin-1/2 particles
  • Familiarity with Hamiltonians in quantum mechanics
  • Knowledge of magnetic fields and their effects on particle states
  • Basic grasp of the relationship between spin and magnetic moment
  • Study the complete Hamiltonian for spin-1/2 particles in magnetic fields, including magnetic moments
  • Learn about the role of the gyromagnetic factor in determining energy states
  • Explore the implications of reversing magnetic field direction on energy states
  • Investigate the Pauli equation and its applications in non-relativistic quantum mechanics
Physicists, quantum mechanics students, and researchers interested in the behavior of spin-1/2 particles in magnetic fields.
docnet
TL;DR
is spin up or spin down higher in energy?
I am confused about why spin down has a lower energy than spin up. What is the correct interpretation of the equations?
If we have a spin ##\frac{1}{2}## particle in a magnetic field ##B_0## that is applied in the positive z direction
The spin states of the particle are
$$\ket{up} = \begin{bmatrix} 1\\0\end{bmatrix}$$
$$\ket{down} = \begin{bmatrix} 0\\1\end{bmatrix}$$
and the hamiltonian for the spin in the magnetic field is $$\hat{H}=\frac{\hbar\omega}{2}\sigma_z$$
to find the energies of the spin states, we operate on ##\ket{up}## and ##\ket{down}## with ##\hat{H}##
$$\hat{H}\ket{up} =\frac{\hbar\omega}{2} \begin{bmatrix} 1 & 0\\0 & -1\end{bmatrix}\begin{bmatrix} 1\\0\end{bmatrix}=\frac{\hbar\omega}{2}\begin{bmatrix} 1\\0\end{bmatrix}=\frac{\hbar\omega}{2}\ket{up}$$
$$\hat{H}\ket{down} =\frac{\hbar\omega}{2} \begin{bmatrix} 1 & 0\\0 & -1\end{bmatrix}\begin{bmatrix} 0\\1\end{bmatrix}=-\frac{\hbar\omega}{2}\begin{bmatrix} 1\\0\end{bmatrix}=-\frac{\hbar\omega}{2}\ket{down}$$
so the energy of ##\ket{up}## is ##\frac{\hbar\omega}{2}## and the energy of ##\ket{down}## is ##-\frac{\hbar\omega}{2}##. The energy of ##\ket{down}## is lower than up..and it is a negative value. are states allowed to have negative energies? why does down have a lower energy than up?
You left out a factor of ##B_0## here. That factor is necessary; see further comments below. (There is also a factor of the magnetic moment of the particle, but we can assume that to be ##1## for this discussion, although its sign is still important; see below.)
Only because you left out the rest of the Hamiltonian. The energies you are evaluating are really the difference in energy between the energy without any magnetic field present (in which case spin up and spin down both have the same energy) and the energy with the field present (in which case the energy of spin down is reduced and the energy of spin down is increased from the "no field present" value).
If you included the entire Hamiltonian, which, to be really complete, has to include the rest energy of the particle (i.e., its mass in energy units), the energies would all be positive.
docnet said:
Summary:: is spin up or spin down higher in energy?
Because the field is pointing in the positive ##Z## direction, and the state you are calling "up" has its spin pointing in the same direction, and the way you have written the Hamiltonian (with a positive sign) makes that add energy to the state. If you reversed the direction of the field, you would also reverse the sign of the energy differences. To see this, put ##B_0## back into your Hamiltonian, as noted above; then flipping the sign of ##B_0## (which corresponds to reversing the direction of the field) will also flip the signs of the energies.
In other words, what you are really seeing here is that, given your assumptions, it takes more energy to have the spin pointing in the same direction as the magnetic field, than to have it pointing in the opposite direction from the magnetic field. Note that your assumptions implicitly include the charge of the particle (which appears in the sign of its magnetic moment, which, as above, also needs to be included as a factor in the Hamiltonian); if you flip the sign of the particle's charge, leaving everything else the same, you also flip the sign of the energies.
More precisely the corresponding part of the Hamiltonian is ##\hat{H}=-\hat{\vec{\mu}} \cdot \vec{B}##. The relation between spin and magnetic moment (in non-relativistic QM) is ##\hat{\vec{\mu}}=g q \hat{\vec{s}}/(2m)##, where ##g## is the gyromagnetic (or Lande) factor. For an elementary spin-1/2 particle like an electron it's close to two (the tree-level value from the Dirac equation/relativistic QED or in the non-relativistic approximation, i.e., the Pauli equation).
  • · Replies 0 ·
  • · Replies 17 ·
  • · Replies 16 ·
