Slope of Tangent Line for y = sin(2πx) at x = 1 and x = 2
The discussion centers on finding the slope of the tangent line for the function f(x) = 1/x at a = 2 and explores the concept of secant lines in relation to tangent lines. The correct formula for the slope of the tangent line is established as f'(a) = -1/(2(2+h)), which approaches -1/4 as h approaches 0. Additionally, the conversation touches on the sine function y = sin(2πx), noting that it has equal derivatives at x = 1 and x = 2, specifically y'(1) = y'(2) = 2π.
  • Understanding of calculus concepts, specifically derivatives
  • Familiarity with the limit definition of the derivative
  • Knowledge of trigonometric functions and their derivatives
  • Ability to manipulate algebraic expressions and find common denominators
  • Study the limit definition of the derivative in depth
  • Learn about the properties of trigonometric functions, specifically y = sin(2πx) and y = cos(2πx)
  • Explore the relationship between tangent lines and secant lines in calculus
  • Practice finding slopes of tangent lines for various functions using derivatives
Students and educators in calculus, mathematicians interested in the properties of derivatives, and anyone seeking to understand the relationship between tangent and secant lines in mathematical analysis.
DB
really isn't calculus but that's the name of my class so, anyway I am having a problem here. i think its pretty simple I am just missing something. I am supposed to find the slope of the tangent line using one point and:
slope of tangent line =
\frac{f(a+h)-f(a)}{h}
h\rightarrow0
find slope of tangent line:
f(x)=\frac{1}{x}
at a=2
so,
\frac{1}{2+h}-\frac{1}{2}*\frac{1}{h}
common denominator X by (1+h)
\frac{1}{2+h}-\frac{1+h}{2+h}*\frac{1}{h}
\frac{1-1-h}{2+h}*\frac{1}{h}
\frac{-2-h}{2+h}*\frac{1}{h}
\frac{-1(2+h)}{2+h}*\frac{1}{h}
\frac{-1}{h}
make "h" zero and I am stuck...
Ummm... Is 1/2 the same as (1+h)/(2+h)?
thanks
okay stupid mistake, now I am stuck again tho
\frac{2}{2(2+h)}-\frac{(2+h)}{2(2+h)}*\frac{1}{h}
comes out to
\frac{-1}{h}}*\frac{1}{h}
gives me -1/h which doesn't work, darn
You need a factor of h in the first denominator for the denominators to be equal.
i don't understand
The denominator of the first term expanded is (4+2h) while the second term's denominator is (4h+2h2)
but those are different terms, arent i looking for a common denominator?
If f(x)=\frac{1}{x}, then
\frac{f(a+h)-f(a)}{h} = \frac{\frac{1}{2+h}-\frac{1}{2}}{h} = \frac{1}{h(2+h)}-\frac{1}{2h} = \frac{2-(2+h)}{2h(2+h)}
=-\frac{1}{2(2+h)}\rightarrow -\frac{1}{4} \mbox{ as }h\rightarrow 0
Yes which is why you need to multiply the first term by h/h so that you have a common denominator.
thanks for the replies, but i don't understand how the c.d is 2h(2+h)
finally, got it
I was wondering one thing about tangent line. Since tangent lines can also be secant line, I actually had a question about secant line. Is it possible for a secant line to intersect 2 consecutive points of a curve? I guess what I am trying to get to is, in a curve, can two, next to each other points be in a straight line?
What do you mean by two consecutive points? Between any two points on a curve there are an infinite number of other points so there really isn't such a thing as consecutive points in the way you are probably thinking. But if you mean like 2 points on a curve where say x = 1 and x = 2, then sure you just have to find a function with equal derivatives at those points, I can't think this through completely right now but that's the gist of it.
Can you give me an example?
Can you give me one of what you mean by consecutive points?
Are you referring to something like y=sin(2πx) ?
It has equal derivatives at x=1 and x=2 (i.e., y'(1)=y'(2)=2π)
No not quite, since that gives a nice counterexample to what I was thinking, errr... I guess not what i was thinking but what I wrote since what I was thinking was that if there are two points on a curve, if the derivative at both of these points are equal and the tangent lines at each point have the same y intercept then they must be the same line and the tangent line would be a secant line. With a sine function like the one you mention you'll have the equal derivatives and hence slopes of the tangent lines are the same but the y intercepts are different. But again with that same function consider y=1 this will be tangent to that curve for x=1/4+n where n is an integer, but this probably isn't quite what the original poster was talking about and isn't exactly what i was either. If you still don't get what I mean I'll try and write up a better post and find a good example of this tomorrow.
:smile: Perhaps you were thinking of y=cos(2πx) ?
Where y'(1)=y'(2)=0 and the single line y=1 is tangent to y(x) at x=1 and x=2
(generally, as y=1 is tangent to y(x) here for all integer 'x')
Well y=1 is tangent to sin(2πx) for all x of the form 1/4+n where n is an integer, isn't it? Because you would have sinn(π/2 + 2πn) which is 1 for every integer n, isn't it? You're example works to, and is better than mine since you don't have to have the 1/4 part.
  • · Replies 53 ·
  • · Replies 20 ·
  • · Replies 21 ·
  • · Replies 22 ·
