MHB Simple Simultaneous equation help
  • Thread starter Thread starter nacho-man
The discussion revolves around solving a system of simultaneous equations involving variables x1, x2, and a parameter λ. The user successfully derived λ* as λ* = √(w1w2/ȳ) but struggles to find the correct form of x*. Another participant points out that the correct solution for x* is x* = (√(w2ȳ/w1), √(w1ȳ/w2)), correcting the user's earlier omission of square root signs. The user expresses gratitude for the clarification, indicating that the solution was confirmed. The focus remains on solving the equations accurately within the given constraints.
nacho-man
Assuming $x_1, x_2 \geq 0, \lambda \neq 0, w_1,w_2 > 0$
We have the equalities:
$$w_1 - \lambda x_2 = 0 ... (1)$$
$$w_2 - \lambda x_1 = 0 ... (2)$$
$$\bar y - x_1x_2= 0 ... (3)$$
My solutions say that $\lambda^* = \sqrt\frac{w_1w_2}{\bar y}$
Which I was able to solve myself.
The other solution is $x^* = (\frac{w_2 \bar y}{w_1}, \frac{w_1 \bar y}{w_2})$
Which I cannot seem to get. Would anyone be so kind as to point out how to obtain solutions for $x^*$ ?
I tried:
$x_1= \frac{w_2}{\lambda}$ and $x_2 = \frac{w_1}{\lambda}$
then put these into the 3rd equation, but ended up gettig
$\bar y = \frac{w_1w_2}{\lambda^2}$ which I couldn't see turning into what I needed either way - even just subbing in one of the x-values at a time, but to no avail.
Mathematics news on Phys.org
anyone? :(
If I wasn't clear, $x^* = (x_1,x_2)$
Hi nacho,
The square root signs are missing in the answer for $x^*$. It should be $x^* = (\sqrt{w_2 \bar{y}/w_1}, \sqrt{w_1\bar{y}/w_2})$.
this was a suspicion of mine - thank you!
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
