Simple Transformations Questions
  • Thread starter Thread starter The Matador
    Transformations
The discussion focuses on the transformation of the graph of y=√x to y=√(9x), identifying the nature of the stretches involved. It concludes that this transformation can be described as a horizontal stretch by a factor of 1/9 about the y-axis or a vertical stretch by a factor of 3 about the x-axis. The confusion arises regarding the horizontal stretch, with participants discussing the relationship between the square root of 9 and the resulting factors. It is clarified that changes in x occur before applying the base function, while changes in y occur afterward. The conversation emphasizes the importance of understanding how transformations affect both axes in graphing functions.
The Matador
Sorry I don't know how to show the root sign on the forums so I am just going to use /
A stretch is applied to the graph of y=/x to produce the graph of y=/9x . Relative to the x and y axis, this stretch may be described as either a... (then it lists a, b, c, or d answers)
The answer is:
horizontal stretch by a factor of 1 over 9 about the y-axis or a vertical stretch by a factor of 3 about the x-axis.
2. The attempt at a solution
I understand that the root of 9 is 3, so it makes sense to me that the vertical stretch is 3. But what I don't understand is why is the horizontal stretch is 1 over 9. Should I not find the root of that and then it be 1 over 3? The only thing I can think of is the the 9 is like this /(9x) and I have to take the 9 out and then I still have a nine outside. /9 = 3 then 3^2 = 9 again. So it comes out to be 1 over 9.
I also assume, although I'm not sure if I'm correct is the reason that it can be a vertical or horizontal stretch is because its not defined in the equation as being a vertical or horizontal stretch.
The answer is:
Obviously y= \sqrt{9x} is the same thing as y= 3\sqrt{x}. Since your base equation is y'= \sqrt{x'} (I put the primes on to distinguish the "old" equation from the new), thinking of this a "change in y" it is y= 3y'= 3(\sqrt{x}): the "old value of y" is multiplied by 3 so it is a "stretch" of 3 of the vertical y-axis. However, thinking of this as a change only in x, y= \sqrt{x'}= \sqrt{9x}: x'= 9x or x= (1/9)x'. The "old value" of x' is multiplied by 1/9, not 1/3. Changes in x occur before the "base" function (here \sqrt{x}) is applied, changes in y occur after.
(Click on the equations to see the Tex code.)
Ok thanks for clarifying that for me.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
