Simplification and manipulation
  • Topic:
  • Thread starter mathnap7
    Manipulation
4 replies · 2K views · last reply
mathnap7
Hi All,
I've been stuck on a problem and after much simplification, it has been reduced to the following:
Is it possible to factor out the (a^2 - b^2) bit. For example, if a = b, the equation would not be valid. Is there any way to factor it out using manipulation?
Best wishes,
'nap
mathnap7 said:
Hi All,
Best wishes,
'nap
Well [math]a^2 - b^2 = (a + b)(a - b)[/math] but it sounds like you are after something different. Can you post the whole problem?
-Dan
mathnap7 said:
Hi All,
Best wishes,
'nap
This is a relatively common expression known as the difference of two squares and is well worth committing to memory to save time
$$a^2-b^2 = (a-b)(a+b)$$
Apologies, I am not too familiar with using the LaTeX plugin.
\frac{a^2b^3}{2(a^2-b^2)}\frac{(cos\phi -1)}{(a^2sin^2\phi +b^2cos^2\phi}
The expression is
\frac{a^2b^3}{2(a^2-b^2)}\cdot\frac{\cos\phi -1}{a^2\sin^2\phi +b^2\cos^2\phi}
Is there a problem in leaving it like this?
The original expression is indeed undefined when $a=b$, and it is not just a removable singularity. Algebraic manipulations will not make it defined when $a=b$.
It may indeed help if you post the whole problem.
