Simplify Pythagoras Theorem Homework Statement
  • Thread starter Thread starter shanshan
    Pythagoras
The original poster attempts to simplify an expression derived from the Pythagorean theorem, specifically involving trigonometric functions and algebraic manipulation.
  • Mathematical reasoning, Assumption checking
  • Participants discuss the simplification steps taken by the original poster, questioning the accuracy of algebraic expansions and the application of trigonometric identities.
Some participants have offered hints regarding potential errors in the original poster's calculations, while others have pointed out specific mistakes in the algebraic manipulation. The discussion is ongoing, with multiple interpretations of the simplification process being explored.
Participants note that the original expression involves fractions and squaring terms, which may have led to confusion in the simplification process. There is an emphasis on ensuring that all terms are correctly accounted for in the algebraic steps.
shanshan
I need to simplify vf = [(vcosx/2)^2+((2v-vsinx)/2)^2)]^1/2
as far as possible
= [(v^2cos^2(x)+v^2sin^2(x)+4v^2+2vsinx)/2]^1/2
= [(v^2(1)+4v^2-2vsinx)/2]^1/2 ---- using trig identity sin^2x+cos^x = 1
= [(5v^2-2vsinx)/2]^1/2
But this is not the answer - is anyone able to find any problems in my work, or can I simplify it further?
Hint: you forgot to square the 2's in the denominator.
tried this - ended up with:
[5v^2-2vsinx)^1/2]/2
and this still wasn't right.
Do you see any other problems?
Yes, I do. You expanded (2v - v sin(x))2 incorrectly. Check that again.
ok, your first step has an error in it. "v^2cos^2(x)" should be over 4 because it was over 2 in the original equation. You did the same thing with the second term of the original equation. Changing that will let you add the fractions more easily. Also when you squared 2v-vsinx you should get v^2sin^2(x)+4v^2-4v^2sin(x) all over 4 Now, you can put all the terms over 4 and pull out 1/4 and v^2. so,
v^2(1/4)[cos^2(x)+sin^2(x)+4-4sin(x)]^1/2=[v^2(1/4)[5-4sin(x)]]^1/2=
=v/2[5-4sin(x)]^1/2. That's as far as I could take it. I think that it was a good effort by you but you may have rushed through and made some algebra mistakes which took you way off course. Actually, using the identity is easy, it's manipulating with algebra that's hard! Good luck with the class
mjjoga
32K
  • · Replies 17 ·
  • · Replies 17 ·
