Simplifying a series with the ratio test
6 replies · 2K views
MathewsMD
Determine if the following series is divergent or convergent:
## ∑_1^∞ \frac {(2)(4)(6)...(2n)}{n!} ##
2. The attempt at a solution
I understand this can be simplified to:
## ∑_1^∞ \frac {(2^n)(n!)}{n!} ##
This can easily be seen to be divergent.
But when I do ## lim_{n→∞}\frac {a_{n+1}}{a_{n}} = lim_{n→∞}\frac {1}{n} ## after simplifying. Does anyone know what I may be doing wrong or why this is not appropriate? Is there any restriction on when the ratio test can be used? Thank you! :)
AlephZero said:
How did you get that? (It is wrong).
I know ## a_n = \frac {(2)(4)(6)...(2n)}{n!} ##
So ##\frac {a_{n+1}}{a_n} = [\frac {(2)(4)(6)...(2(n+1))}{(n+1)!}] [\frac {n!}{(2)(4)(6)...(2n)}]##
This simplifies to: ## \frac {2(n+1)}{2n} \frac {1}{n+1}##
Now, when the limit is taken as n→∞, then ## \frac {2(n+1)}{2n} = 1## and you're left with ##lim_{n→∞}\frac {1}{n+1} ## I just simplified this to ##\frac {1}{n}##. Does anyone mind telling me what I did wrong here?
No, the ratio is 2(n+1)/(n+1)=2. Where did the extra n come from??
ahh i forgot to cancel a 2n
Why bother with the ratio test? The nth term of the series equals ##2^n## (as you have already noted). Since ##2^n## does not go to 0 as ##n \to \infty## the series cannot possibly converge.
Yep, I just didn't know why using a different test that I wasn't getting the same solution. Problem's solved.
