Undergrad Can the Double Summation be Simplified?
The discussion focuses on simplifying the double summation $$ \sum_{i=1}^{n-1} \sum_{j=i+1}^n a_i a_j $$. A suggestion is made to rearrange the sum to express it in a more compact form, potentially losing one of the summation symbols. It is noted that while the original sum does not include terms like $$a_i^2$$, adding these terms can lead to a more concise expression. The conversation also touches on the complexity of indexing in double sums, with some participants expressing confusion over the notation used. Overall, the thread emphasizes the possibility of simplification through rearrangement and the inclusion of additional terms.
Josie Jones
Hi, I am trying to simplify a double summation and was wondering if anyone would be able to help me.
The sum is
Is it possible to simplify it down and maybe lose one of the sigmas?
Thank you in advance :)
Mathematics news on Phys.org
Yes. Consider ##\displaystyle \sum_{i=1}^{n-1} \sum_{j=1}^{i-1} a_i a_j##. You can rearrange that until it looks like your original problem. This, plus the original sum, plus the sum over ##a_i^2## can be expressed much shorter, and that gives you a way to express your sum in a more convenient way as well.
All these steps are easier to follow if you draw a table (i,j).
There are no a_i^2 terms.
Not in the original sum, but if you add these terms (in a suitable way) you can get a nice compact expression. The original sum is then the difference between a nice compact expression and the sum of these squares (with suitable prefactors).
so if this $$ \sum_{i=1}^{n-1} \sum_{j=i+1}^n a_i a_j $$ is taking elements from the same vector a of size n and summing the products of adjacent elements, then why can't you write it as $$ \sum_{i=2}^{n} a_i La_i $$ where L is the Lag Operator:
862131b68e4a017e26f0a9c5e34af12fd42ce10c
for all t >1 (or a and index i in this case)
@BWV: That is a completely different sum.
Yes it is, the indexes in the OP are such a mess, I guessed at what perhaps was being attempted. The double sum with one index depending on the other does not make any sense to me
Huh? That is very common, and the notation is nothing unusual either. The range of elements to be summed over in the inner sum depends on the index of the outer sum. So what?
  • · Replies 16 ·
