Simplifying limit with Stirling approximation
The discussion revolves around evaluating the limit $$ \lim_{N \rightarrow +\infty} ln( \frac {N!} {(N-n)! N^n}) = 0$$ using Stirling's approximation. Participants explore the implications of Stirling's approximation in the context of factorials, addressing both theoretical and practical aspects of the limit as N approaches infinity, while also considering the role of n as a smaller integer than N.
  • Some participants propose using Stirling's approximation, $$ ln(N!) \approx Nln(N)-N $$, to evaluate the limit term by term.
  • Others argue that there are incorrect signs in the initial formulation of the limit, suggesting that terms should be subtracted rather than added.
  • A later reply questions the validity of using Stirling's approximation directly in the limit evaluation, stating that the discrepancy between the approximation and the actual factorial grows as N increases.
  • One participant suggests an alternative approach without using Stirling's approximation, analyzing the limit directly through the ratio of products.
  • Another participant notes that all limits should be evaluated as N approaches infinity rather than n, correcting a previous misunderstanding.
Participants express differing views on the use of Stirling's approximation and its implications for the limit. There is no consensus on the correct approach or the validity of the steps taken in the limit evaluation.
Some participants highlight that Stirling's approximation is asymptotic and should not be treated as exact, indicating that the limits involved may lead to indeterminate forms.
This discussion may be useful for those interested in advanced mathematical techniques, particularly in the context of limits, factorials, and asymptotic analysis in combinatorial contexts.
lholmes135
TL;DR
Using stirling approximation to determine limit at infinity is not giving the correct answer.
I'm trying to determine why
N and n are both positive integers, and n is smaller than N. I want to use Stirling's, which becomes exact as N->inf:
And take it term by term:
$$ \lim_{N \rightarrow +\infty} ln(N!) + \lim_{N \rightarrow +\infty} ln((N-n)!) + n \lim_{N \rightarrow +\infty} ln(N))$$
$$ \lim_{N \rightarrow +\infty} [Nln(N)-N] + \lim_{N \rightarrow +\infty} [(N-n)ln(N-n) - (N-n)] + n \lim_{N \rightarrow +\infty} ln(N))$$
I don't really know where to go from here. I tried using the approximation (N-n) = N:
$$ \lim_{N \rightarrow +\infty} [Nln(N)-N] + \lim_{N \rightarrow +\infty} [Nln(N) - N] + n \lim_{N \rightarrow +\infty} ln(N))$$
$$ \lim_{N \rightarrow +\infty} [Nln(N)-N + Nln(N) - N + nln(N))]$$
$$ \lim_{N \rightarrow +\infty} [(2N(ln(N)-1)+nln(N)]$$
But that limit goes to infinity.
lholmes135 said:
Summary:: Using stirling approximation to determine limit at infinity is not giving the correct answer.
In the equation above, you have two incorrect signs.
$$\ln \frac A {BC} = \ln A - \ln(BC) = = \ln A - (\ln B + \ln C) = \ln A - \ln B - \ln C$$
In your equation the 2nd and 3rd terms should be subtracted, not added.
Thanks Mark, good catch. So fixing the signs and using the same N-n = N approximation we have:
$$ \lim_{N \rightarrow +\infty} {[Nln(N)-N]} - \lim_{N \rightarrow +\infty} {[(N-n)ln(N-n) - (N-n)]} - n \lim_{N \rightarrow +\infty} {ln(N)} $$
$$ \lim_{N \rightarrow +\infty} {[Nln(N)-N]} - \lim_{N \rightarrow +\infty} {[Nln(N) - N]} - n \lim_{N \rightarrow +\infty} {ln(N)} $$
$$ - n \lim_{N \rightarrow +\infty} {ln(N)} $$
$$ -\infty $$
I still can't get 0 out of this.
Stirlings approximation does not become "exact" as ##N \rightarrow \infty ##.
i.e ##lim_{N \rightarrow \infty} ( N \ln(N) - N - ln(N!) ) \ne 0 ##
The step above isn't valid. In essence, with regard to the 1st and 2nd terms, it is saying that ##\infty - \infty = 0##, which isn't necessarily true. As a limit, the indeterminate form ##[\infty - \infty]## can result in a limiting value anywhere between negative and positive infinity.
Expanding the 2nd term, you get ##N\ln(N - n) - n\ln(N - n)##
Is it a requirement in this problem to use Stirling's approximation? Evaluating the limit would be simpler just to work with it as it is.
$$ -\infty $$
Stirling's approximation is ##m!\approx \sqrt{2\pi m}(\frac{m}{e})^m## Try using it.
Proceeding that way, term by term is not valid.
Regardless of which version of Stirlings approximation you use, it isn't valid to to replace each factorial by it's Stirling approximation because, as indicated previously, if ##S(N!)## a Stirlings approximation for ##N!## the descrepancy between ##S(N!)## and ##N!## approaches ##\infty## as ##N \rightarrow\infty##
Stirlings approximation is an asymptotic approximation. So the only valid way to use it is in the form ##\lim_{N \rightarrow \infty} \frac{N!}{S(N!)} = 1## or ##\lim_{N \rightarrow \infty} \frac{S(N!}{N!} = 1##.
If you are required to use Stirlings approximation, you should look for ratios in the problem that resemble the above two fractions.
I suppose I should add some context. This isn't homework. My textbook is deriving a certain formula and I'm trying to follow the derivation. At one step they say something like "and obviously we can use the Stirling formula to show that ..." and show the equation in question. Mathman has posted a better version of the Stirling formula, but the crude version my textbook uses is $$ln(N!) = Nln(N) - N $$
That said, it isn't really a requirement to use the formula. I just want to understand any derivation.
@Stephen Tashi By "exact" I more meant that $$ \lim_{n \rightarrow +\infty} {\frac {Nln(N)-N} {ln(N!)}} = 1 $$
Regardless, I think I see the point you are making that I can't replace it in the expression, and Mark's that I can't replace (N-n) with N.
Also I've been out of school for four years, and this is the first serious math problem I've worked on in that entire time. Hence why I'm doing stupid stuff like mixing up my signs.
I think I have an explanation without the Stirling approximation.
$$ \lim_{n \rightarrow +\infty} { \frac {N!} {(N-n)!N^n} } $$
$$ \lim_{n \rightarrow +\infty} { \frac {N*(N-1)*...*(N-n+1)} {N*N*...*N} } $$
There are n terms in both the numerator and denominator, so this can be written as
$$ \lim_{n \rightarrow +\infty} { \frac {N} {N} * \frac {N-1} {N} * ... * \frac {N-n+1} {N} } = 1$$
$$ \lim_{n \rightarrow +\infty} { \frac {N!} {(N-n)!N^n} } = 1$$
$$ \lim_{n \rightarrow +\infty} { ln ( \frac {N!} {(N-n)!N^n} )} = 0$$
I appreciate all the help, thank you guys.
Based on the original problem, all of the limits in the previous post should be as ##N \to \infty##, not as ##n \to \infty##.
  • · Replies 17 ·
  • · Replies 16 ·
