Sizing motor and gearbox for 1000 lb lifting device with chain drive
  • Thread starter Thread starter rbees
    Lifting
28 replies · 15K views
rbees
Need engineering help -- lifting 1000 lbs 16 feet
Ladies & Gents,
I am trying to engineer a lifting device. I can build the frame and all that but getting the motor and gearbox sized right is my problem. I am not a math wizz. Some algebra in middle school many many years ago .
The load I want to lift is 1000 lbs. The vertical travel distance will vary from 8' to 16'. The travel speed need not be very fast, 12 inches a min is plenty because there may be binding issues during said travel. I had figured to use a 3" sprocket and chain on the gearbox to do the lifting with. What I don't know is how to translate that 1000 lbs into a motor size. Keeping the motor/gearbox assembly light is one of the desired design features as it will need to be moved by hand repeatedly.
I have looked on google and found lots of info but translating that into actual useful numbers is beyond me.
Can anyone help me?
Thanks
I am sure my math has problems but this is what I have at this point.
Sprocket radius
0.125 feet
Lift Weight
1000
Ft Lb torque
.125*1000 = 125
Sprocket Circumference
2*PI*.125 = 0.7854 feet
Lift Height
Lift Time (min)
Output RPM
15/(16/.7854) = 0.7363
Input RPM
1750
Gear Ratio
1750/.7363 = 2376.714
Horse Power
.7854*.7363/5250 = 0.01753
I have this set up in a spreadsheet but when I change the lift time from 15 to 30 min my ratio goes in the wrong direction. I have been using the formulas here. http://machinedesign.com/technologies/gearmotor-sizing-guide
if my ratio is correct I will need to further reduce the ratio by chain & sprocket, not really a problem.
Thanks
It's not clear from your post if you are using any tackle (pulleys and sheaves) in your lifting device. There's more to engineering than throwing a bunch of numbers on a sheet of paper.
Since I didn't mention them, no there are none, besides I have never seen them work well with roller chain ;).
Having though about what I want to do and the best way to do it I chose roller chain over wire rope. I considered using screw jacks but getting an adjustable screw length for the different distances I need to move the load is problematic without having separate screws for each length and needing as many as 18 of each that gets expensive. Wire rope has its own problems, fraying, kinking and without using block & tackle heavy and hard to manage.
With #60 roller chain I can run one chain from the lifting point to the lifted point and pull. Very simple. Also rotational/twisting of the lifted load is not an issue although binding may be. If I need more lifting length I can add chain easily with a master link. When the lift is done the chain can be rolled up and stored in a 5gal bucket. No sheaves (shivs) for the wire rope to come off and be damaged by and no screw to get damaged during storage and / or assembly.
Still you didn't mention if there was a problem or lack of problem with my math.
Thanks
I actually have a crude dxf drawing drawing of the basic design but I hesitate to upload it because it contains sensitive information.
Well, in that case, I understand.
Still, trying to hoist something slowly when your motor is turning at 1750 RPM is tricky, if you don't use some kind of reduction gear to slow things down.
From my earlier post
As far as that goes I do not have to use a 1750 motor. They are common and it theory, cheaper. The mechanical part is NOT the problem. The problem is getting the math on the gear motor right so that I get units that are big enough but not excessively big and heavy as they have to be carried by hand up and down a ladder in soft sand.
Understanding how the math is suppose to work is my problem. And still I am only getting responses about the mechanics.
FYI: Moderators; this site seams to be trying to load something that it is unable to download, even after setting all night it still does not complete. At least in Opera on Debian Linux. Also I am behind a firewall that drops all data to and from know hacked sites. See http://www.spamhaus.org
Thanks Baluncore
My grandpa actually had one of those now that I think about it. But that won't work very well for me in this app because the drive unit actually needs to climb the chain, not the other way around. Quality #60 roller chain has a 7000 lb tinsel strength. Plenty strong enough to lift 1000 lbs me's a thinkin. Also this is not a continuous duty device, if it gets used once a month over the coarse of a year it will have been a real good year.
Still no one has mentioned why the math posted above is not working as I think it should.
On another note; when a supplier of gear boxes lists a horsepower rating is that rating normally for the input or output?
The work you want to do is pulling a force (F) at a desired speed (V). The power (P) you need is:
P = F*v (in metric units)
1 lb is 4.448 N and 1 m/s is 2362 in/min, so: 1000 lb is 4448 N and 12 in/min is 0.00508 m/s, hence:
P = 4448 N * 0.00508 m/s = 22.6 W or 0.03029 hp (1 hp = 746 W)
You will have to add some losses to that power (like friction), but this is you basic number to size your motor.
Sprocket radius
0.125 feet
Lift Weight
1000
Ft Lb torque
.125*1000 = 125
Lift Height
Lift Time (min)
Output RPM
Input RPM
1750
Gear Ratio
Horse Power
Thanks
A couple of mistakes in this. Let me redo your work:
Sprocket radius
0.125 feet
Lift Weight
1000
Ft Lb torque
.125*1000 = 125
Lift Height
Lift Time (min)
Output RPM
(16/.7854)/15 = 1.3581
Input RPM
1750
Gear Ratio
1750/1.3581 = 1288.565
Horse Power
125*1.3581/5252 = 0.03232
As you can see, it gives the same number as previously calculated (It's a little higher because 16 ft in 15 min is a speed of 12,8 in/min instead of 12 in/min).
The power rating should represents the input power, as it is always the largest of the two.
Although, in theory, the input power is equal to the output power.
That is the beauty of the notion of power: Power stays constant throughout any process (less some losses like bearing friction). What goes in must comes out. So the input power is the same as the output power, only the torque and rpm are different (Tin * RPMin = Tout * RPMout).
Thanks jack action,
You have been much help. I got the formulas fixed in my spreadsheet and now it calculates motor sizes as it should.
If I am understanding you correctly this gear box would be suitable for what I am trying to do.
http://www.surpluscenter.com/Power-Transmission/Gear-Reducers-Gearboxes/Right-Angle-C-Face-Input-Gear-Reducers/60-1-RA-GEAR-REDUCER-0-6-HP-IEC-71B14-LEESON.axd
SPECIFICATIONS
Ratio 60:1
Power 0.6 HP max.
Input Speed 1750 max.
Output Speed 29.16 RPM max.
Torque 445 in.-lbs. max.
Motor Mount IEC 71B14
Input Shaft 14mm keyed hollow input bore
OutputShaft 1-1/8" diam. x 3-3/16" thru length hollow output bore
Mount Four tapped mounting holes on each output side
Size 5-1/2" x 6-1/2" x 4-3/16"
Shpg. 9 lbs.
All I would need to find is suitable motors to go with them and gear it down a little more with an extra set of step sprockets.
Thanks
I agree with those numbers.
The Lift.
mass of 1000 lbs = 453.59237 kg
height 16 feet = 4.8768 metres
acceleration of gravity = 9.80665 m/s/s
force = 453.59237 * 9.80665 = 4448.22 Newton
total energy needed is = 4448.22 * 4.8768 = 21693. joule
Motor Power.
1 HP = 745.7 watt
15 minutes = 15 * 60 = 900 second
Power for 15 minutes = 21693. / 900 = 24.1 watts = 0.032 HP
If lifted in 30 minutes = 12.05 watt = 0.0162 HP
If lifted in 5 minutes = 72.3 watt = 0.097 HP
Gearing.
sprocket radius is 0.125 feet
Lift is 16 feet. Motor is 1750 RPM
Total turns = 16 / (2*Pi*0.125) = 20.37 turns
20.37 turns in 15 minutes is 1.358 RPM
Gearbox ratio needed is 1750 / 1.358 = 1288.66
By looping the chain over a top sprocket you halve the chain strength requirement and halve the gearbox ratio required to 644.33
By using a differential pair of sprockets say 32 and 33 tooth, you get another factor of 32 reduction to a gearbox ratio of 19.83
Go to almost any industrial gearmotor supplier site. Most offer a great catalog with Application Engineering section or a standalone AE handbook. Some even have online calculators that will select your gearmotor for you. SEW Eurodrive always had the most rigorous engineering documents in my experience.
Determine your required speed profile. You size your gearmotor for peak torque which will be torque required to accelerate the load from zero speed to max speed in the required time + torque to lift 1000 lbf against gravity + torque to overcome friction + etc etc etc. "Load" will be all the rotational & translational inertias that you must accelerate.
Gearmotors are de-rated based on how many starts per hour. More starts, more heat, bigger motor required.
You'll need a suitable brake to hold the load from falling.
Unless you have all of the mechanical elements already figured out, sizing a gearmotor is usually an iterative process. It requires a few tries to converge on a good answer.
Torque is cheap. Buy plenty of it.
A preliminary way to determine what motor size you're going to need is to just solve for the energy requirements. You want to lift 1000lbs 16ft, so the energy required is 16,000ft-lbs. You also want to lift at 12"/minute (1 ft/min), which means it will take 16 minutes or 960 seconds to lift. So we solve for power: 16000ft-lbs / 960 seconds = 16.67 ft-lbs/sec. Remembering that one horsepower is 550 ft-lbs/sec, you need a motor that can deliver 16.67/550 HP or 0.03 HP. But you will probably need to double that in order to compensate for the losses in the transmission and lift mechanics.
DANGER! I want to add one important point here and that is a chain and sprocket transmission used with an electric motor can be extremely dangerous in a lifting application. If the motor should lose power, there's nothing to stop it from free-wheeling allowing your load to crash to the ground. A worm gear drive is much safer (although not as efficient). Even with a worm drive, a brake should also be incorporated.
Thanks to all.
So 1 tooth difference in sprocket size divides by 32? Some how that does not seam right to me. Please explain.
Another concern I have is the shaft that will hold the main lifting sprocket. The bearing centers will be 7.5 inches apart. There is not much I can do practically to make that narrower. How big a shaft do I need? Sure I can just through an 1.25" shaft in there but such a big shaft limits how small the lifting sprocket can be. If I could use a .75" shaft I could use a smaller lifting sprocket and further reduce my required ratio.
My dad is missing fingers on his right hand because an 8N Ford tractor he was working on fell, even though he thought he had it properly blocked up. Needless to say I grew up learning a very healthy respect for things that can fall.
Just the other week we were fixing a freight lift that the slack-chain safety stops had not worked correctly on and it broke the chains. One of the electrician's helpers was standing down below and claimed he could jump out of the way if we lost the chain again while we were putting it back on. I made him get out of the fall radius anyway. Sure enough not 5 min later the other chain slipped and went crashing down right where he had been standing. Point, YOU CAN NOT MOVE FAST ENOUGH WHEN SH** HAPPENS.
Yes I am planning to put a spring loaded mechanical pinch brake/stop in the system. Even if it did not hurt somebody I still can't afford $15000.00 to repair/replace the damaged material such a disaster would cause.
Maybe you have not understood differential gears with an endless chain in two loops. The two sprockets are locked together on the same shaft so one revolution of the sprockets takes in 31 links but releases only 30 from the supporting loop. That shortens the loop of chain by one link per rotation of the sprockets.
You have the two falls of the supporting chain loop, not just only the one supporting the load. The chain shortening is in a loop of chain so you keep the factor of two reduction by having an idler. It also halves the weight of the chain required.
If you put the differential pair at the top and the idler at the load then you can drive the idler to lift the load if you do not want to drive the differential pair above.
Another advantage is that you can use safer lifting chain that is much stronger and cheaper. Link chain is less likely to run without motor power than roller chain. Because it is easier to lubricate and is less liable to damage than roller chain it is not so certain to result in a catastrophic failure later. Remember, a chain is as strong as it's weakest link.
Thanks
Yes I do, but I did not realize that that is what you were talking about. But thanks for the through explanation of how they work.
The chain may be cheaper but I have yet to find anyplace to buy the sprockets. You have a US supplier?
The Differential sprockets are a good idea but they have a problem that I don't see an easy way around. Just like the screw jack method needing a different screw for each different lifting height the differential sprockets would need a different length chain for each different lifting height. Unless you know a way to magically grow and shrink a welded link chain. : ) As I understand it the idler sprocket used to drive the differential sprockets above must remain in a fixed location to keep the slack out of the chain. On some other method of keeping the slack under control must be devised. Simple is better. Less things to go wrong. KISS
Take a look at this video that shows the goal but not the method
http://www.google.com/url?sa=t&rct=...pIp2N3xm9TfRTf0hQnswiNg&bvm=bv.56643336,d.b2I
His method has a single point of failure (the winch on the dozer) with catastrophic results. My plan is to put a separate lifting device at each post with them all controlled from a single location. That way if anyone fails the the whole thing does not come down. Also note that his barn design is OK for the southern US but will not work in the north where we have lots of snow.
Obviously putting anything very heavy and bulky on top of the posts is problematic and dangerous from a ladder. Often it is not possible to get a man lift in place for putting the units on the post, like the site being off grade or to sandy for them to get around, trees in the way, the list is long. Hence the lifting unit needs to actually be under the header where it can be installed from the ground. Removal after the lift can be achieved with a simple rope thrown over the truss and lower it to the ground.
Thanks
Randy
Make a pole climber using a rack and pinion drive. Attach the rack to the side of the pole and have the pinion drive attached below the rafters. The pinion drive walks up the rack lifting the roof.
With the differential pair at the top and the idler supporting the load there is one loop under tension and another loop hanging freely below. The length of the endless chain remains fixed. To lift 6 metres or less requires 12 metres of chain closed into a loop.
I am not in the US so I don't have a US chain sprocket supplier there. You can do a google image search for "round link chain sprockets". Take a look at these.
http://www.pewagchain.com/Products/Forderketten/Kratzerforderketten/Kettenrader-aus-Guss/IR-Zahnkettenrad-%282%29.aspx
I have made chain sprockets by cutting a deep groove in the periphery of a wheel for the chain edges and then milling recesses for the links with a circular cutter.
rbees: I agree with the post by Baluncore. Make the two integral pulleys shown in the attached file out of a solid block of mild steel. The two pulleys are integrally connected together at their interface, because they are made from a solid block of steel. (Diagram not to scale.) The pulleys shown in Figure 1 have a plain through-hole (not shown) through their center, so that they spin freely on your steel axle. The bottom (movable) pulley (not shown) can be any kind of pulley (pocket, toothed, or plain); probably plain might do (?), but I will defer to Baluncore on that.
First, find the minimum chain size to give you a high factor of safety on one half of your lifted load. Half would be a chain tensile force of 2224 N. Once you get the exact minimum chain dimensions, then you can design and size the pulleys shown in Figure 1. You can also size the axle. To lift your load 4.90 m, I have not yet computed exactly the minimum length of chain you need to purchase. Once you give us all the exact dimensions, we can compute the input force required to lift the load.
Notice that you do not even need to use a motor. Using the above system, you would be able to lift your 454 kg mass by pulling on the chain with something like a mere 67 N (?) of input tensile force, neglecting friction (although I did not check the exact input force yet; and we need to include friction).
Now the problems. Firstly, you cannot have motorised chains catching on things so you need a closed gearbox. Secondly, with multiple blocks you will have synchronisation problems if one stops, motors are not usually synchronous and things do go wrong. Raising barn roofs in this country employs manual chain blocks with manual operators. It happens so rarely that several people for one hour is more cost effective than motorised systems.
Where to start. With the chains catching on things. So let's say I build this thing with log chain, in building construction there always seem to be nails and board splinters, or anyone of a number of thing sticking out of the lumber. So loose chains swinging around is not a good thing and so I don't like that idea.
I do understand the synchronization challenges and I have been thinking about that and have some ideas. Those ideas involve electronics far more than physics and fall outside the scope of this website and so I have not mentioned them.
The problem with manually operating the lifts is that as the building grows in size the number of lifts grows and there comes a point when the man power to operate them becomes hard to come by. Here in the US there is not a ready supply of people that you can hire for an hour or two to raise the roof. On top of that one of the major reason to employ this method is the safety factor gained by doing all the high work at ground level. If you then go at it and have people standing under the load to run a chain fall you defeat that safety gain. Mind you there is typically an overhang on the outside of the building so it is not really possible to not be under the roof or very close to it to raise it manually. As I have mentioned before when sh*t happens you can not move fast enough to get out of the way. Then with exploding lumber peaces flying around it is very unlikely that someone would not be seriously hurt.
When was the last time you priced custom machine work? This needs to be cheep as in inexpensive but effective as in simple to use.
The more I think about this method the more I like it. It is simple, meaning that pretty much any rum dummy can set it up. It avoids the the tinsel strength problems of roller chain with catastrophic results. It avoids the catching dangers of log chain and the expense of custom machine work. It is easy to gear on down to a manageable speed by using a small reversible worm drive to drive with brake to power a second worm drive that drives the pinion/climbing gear. The rack gear can be made in such a way that more can be added without much trouble unlike the screw in a screw jack.
I have not had a chance to examine the cost relationship between the different stiles.
The attached files, Figures 2 and 3, show a crude example of the pulley in post 21, without, and with, a chain on it. This pulley uses a 4.0-mm-diameter annealed stainless steel 304 chain, having a chain pitch of 23.9 mm. This chain has a working load limit of 2250 N, which is ample for your application. This particular pulley has 40 pockets. The 40-pocket pulley diameter, at the chain centerline, is 303.68 mm.
The diagrams show sharp corners, for simplicity; i.e., the edges and corners are not tapered and rounded yet. The diagrams do not show the integral, smaller, 39-pocket pulley yet.
If you could find this pulley to purchase it (including the 39-pocket pulley), instead of fabricating it, that would be great. I currently do not think chain tangling would be an issue.
If desired, you could operate the pulley remotely, by adding another pulley (spool) to it, which has a long cord wrapped around it. Then, to operate the pulley, you just pull the cord, remotely, applying only about 70 N (?) of input tensile force.
I think the aim is to motorise multiple lifts in the system with synchronising electronics that will maintain a linear lift at all points. That precludes hand operation.
Roller chain and round link chain are fundamentally different. The number of links in a roller chain is the number of rollers. In a round link chain the 90° interlinks are counted also so a count of the chain links appears to be twice the number of pockets in the sprocket.
With a differential pulley the number of pockets decides the gear ratio. 40 pockets coupled directly to 39 pockets will differ by one link pair for every 80 links moved, or one full turn of the sprocket pair.
If the motor driven idler then had only 4 pockets, (that is a small square shaft with a simple peripheral groove turned in it on a lathe), then each turn of the idler would move 8 links. The gear ratio would be one link pair shortening of the lifting loop for each turn of the 40 pocket sprocket, which would require ten turns of the square idler sprocket. The tension loop, (two falls), will therefore lift one link only per ten turns of the idler. The gear ratio improves with shorter link chain.
A gear motor turning a 4 pocket sprocket will be a bit lumpy, but those square sprockets work well on normal chain blocks and they are trivial to make from square stock in a lathe.
Baluncore: My mistake. In post 24, I counted the round link chain 90 deg links as a "pocket," loosely speaking, which is wrong. Therefore, the example pulley shown in post 24 is currently a 20-pocket pulley.
I wish someone could find round link chain having a working capacity of 2225 N, and having a much shorter chain pitch than what I used in post 24. Then I could increase the number of pockets up to your original 33 pockets, with 32 pockets for the smaller pulley.
The cord I mentioned in post 24 can be operated remotely either by human or machine. Therefore, if machine operation is needed, no problem there.
Not a mistake so much as a trap that I also fell into earlier. It comes down to lack of definitions. A roller chain can have 39 or 40 teeth on the sprocket but a round link chain cannot have an odd number of links because of the alternating orientation. So it cannot be drawn without resort to M.C.Escher like tricks. There are too many different effects happening here for one brain to handle at one time. No one has pointed out my mistakes, hopefully they are lost in the mists of thread-time.
“Load chain” has short links compared to ordinary round link chain; but load chain is not certified for lifting. The important thing is that the chain dimensions be a carefully controlled standard. The pockets will need carefully controlled angular walls so the chain will roll in and seat at a sufficient depth without interference from either end of the links or from below.
One advantage of roller chain is the short pitch available. I have seen a portable saw mill that employed differential sprockets to set the height of the saw rails. It was a very neat design because the top and bottom sprockets were fixed to the frame while the differential pair was on the carriage in contact with both falls of the chain. As the single loop of chain rotated the differential sprocket rose or fell by one link per turn. The two lifting loops on one end frame were coupled by a cross shaft so the ends remained parallel during the lift. A neat commercial design.
There may be a legal problem with using roller chain to lift a load. I have never seen roller chain approved for lifting, indeed round link chain has to be specially certified for lifting. Roller link chain will corrode with time and will need to be inspected for damage by a certified engineer prior to every application.
I actually installed a model similar to this one.
http://www.autoquip.com/media/239324/Drawings-FLMC%20Freightlite%20Drawing-1.pdf
They have several models that employ roller chain to lift several tons. The one I installed was rated at 2 tons and uses 2 #80 roller chains to do the lifting, and it lifts about 25' if I remember correctly. They sell these units for installation all over the US
I finally found steel round link chain for lifting that is small enough (and excellent) for this application. It is ultra-short pitch. :smile: It is a 4.0-mm-diameter round link chain with a 12.0 mm chain pitch, per DIN 5684-1[/color], grade 5; and it has a working load limit of 2450 N. Hopefully there is a supplier near you who stocks it, or equivalent.
Therefore, we can now go to a 40-pocket pulley, which would have a pulley pitch diameter of 305.42 mm (at chain centerline), with 39 pockets for the smaller pulley, which would have a pulley pitch diameter of 297.78 mm.
