Sketching a graph of contaminants after a train crash
The discussion revolves around graphing a function that models the concentration of a pollutant in a pond after a train derailment. Participants are attempting to understand how to accurately represent the function C(t) = 30t/(200000 + t) and are facing challenges with graphing it correctly.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants are questioning the correct interpretation of the function and its graphing. There are discussions about using graphing calculators and online tools, as well as clarifications regarding the proper use of parentheses in the equation.
Some participants have provided guidance on how to approach graphing the function, including suggestions for identifying the domain and evaluating the function at extreme values. There is an ongoing exploration of the function's behavior and the importance of correct notation.
There are mentions of potential confusion due to missing parentheses in the original equation, which led to misinterpretations of the function. Participants are also encouraged to clarify the units used in the equation.
Bhawna L
After a train derailment in Northern Ontario, the concentration, C, in grams per litre, of a pollutant after t minutes in a 5 000 000-L pond can be modelled by the function C(t) =30t/200000 +t, when a pollutant concentration of 30 g/L flows into the pond at a rate of 25 L/min. a) Sketch a graph showing the concentration of the pollutant after t minutes
See above
I tried to graph this equation, but all I am getting is a straight line that is x=0. I don't understand what I am doing wrong.
How are you trying to graph it? Like on a calculator or something?
Yeah, I tried using an online graphing calculator, but all I'm getting is x=0, which is not what is supposed to be based on the answers that I was given. I am just trying to figure out how to actually graph it.
I'm kind of confused by your question.
Are you asking how to graph the function ##C(t)=\frac{30⋅t}{200000}+t=(\frac{200030}{200000})⋅t##?
The function is ##C(t)=\frac{30⋅t}{200000+t}##
OK, got it. Mind your parentheses, that's not the function you originally typed.
If you are asking how to work a graphing calculator, I am neither interested or capable of helping. But I can help a bit in understanding what this function looks like, with some tricks about graphing in general.
1) Identify the domain of the function, i.e. what values of ##t## do you care about. In this case I'll guess that it's ##0 \leq t \leq \infty##. Then evaluate the function at those limits and put those points on your graph. For infinity, you can put in a really big value for ##t##. Even though you can't graph it at ##\infty##, do it and write down the value.
2) Identify factors in the function that are simple operations on a more basic function. For example ##y=x^2+2##, or ##y=10x^2##, are really just simple variations on ##y=x^2##. Don't waste too much effort on these numbers, just use as required. So from an abstract point of view your function is similar to ##y=\frac{t}{t+a}##, with ##a=200000##, just 30 times bigger.
3) Try to see how the function behaves near the extreme values, you can often approximate the function with a simpler version. For example, in this case, what is the difference between ##C(t)=\frac{30⋅t}{200000+t}## and ##C(t)=\frac{30⋅t}{200000}## when ##t \ll 200000##, for example ##t=1##, ##t=10##, ##t=100##, etc. Same for the large values (##t \gg 200000##, like ##t=10^8##), but a different approximation. This will give you two asymptotic approximate functions that will be very close to the real function at the extremes, but won't work so well in the middle.
4) Sketch those asymptotic functions (dotted lines, usually) as guidelines for where/how the function starts and ends.
5) In the middle section, where ##t \ll 200000## and ##t \gg 200000## aren't true, you'll need to calculate some values and plot them to see how the function makes the transition from one asymptote to the other. I'd start with ##t=200000##, as a good guess.
OK, now the disclaimer. This process doesn't always work. Some functions are a pain in the @##. But you'll probably recognize most of those, or figure out in this process that things aren't simple. For well behaved functions, you can just draw a smooth line to connect the points you calculated and approaching the asymptotes.
Finally, as an enticement: this process will be easier for you in the future when you've learned about calculus and other math stuff.
Thank you! Really appreciate it.
You can copy-paste your equation into https://www.desmos.com/calculator
rather quickly and see what is going on. Use parentheses as needed.
You may have to scale the axes (use the wrench to set values or
shift-mouseDrag on the axes or along the edge for axes out of the viewport).
It might be helpful to clarify the units being used in the equation
to see that the parentheses are in the correct places.
Bhawna L said:
Homework Statement:: After a train derailment in Northern Ontario, the concentration, C, in grams per litre, of a pollutant after t minutes in a 5 000 000-L pond can be modeled by the function C(t) =30t/200000 +t,
Because of missing parentheses, your equation was interpreted to mean this:
$$C(t) = \frac{30t}{200000} + t$$
Much better.
It looks like you (@Bhawna L) have figured out how to use LaTeX to write this equation correctly. If you write fractions inline, it's important to use parentheses in the right places. For your equation, it would be C(t) = 30t/(200,000 + t).
