Are Skew Lines Considered Perpendicular in 3D with Parallel Vectors?
In 3D geometry, skew lines L1 and L2, defined by their respective parametric equations, can have parallel vectors v1 and v2. If the dot product of these vectors, calculated as v1.v2 = ad + be + cf, equals zero, the vectors are perpendicular. However, this perpendicularity does not imply that the skew lines themselves intersect; they can be orthogonal without sharing a point in space. For example, while the x and y axes are perpendicular and intersect in the plane z=0, raising the x-axis to y=0, z=1 results in two perpendicular lines that do not intersect.
  • Understanding of 3D geometry and skew lines
  • Knowledge of vector operations, particularly dot products
  • Familiarity with parametric equations of lines
  • Basic concepts of orthogonality in vector mathematics
  • Study the properties of skew lines in 3D geometry
  • Learn about vector dot products and their implications for orthogonality
  • Explore parametric equations and their applications in 3D space
  • Investigate the concept of planes and intersections in three-dimensional geometry
Students and professionals in mathematics, physics, and engineering, particularly those focusing on 3D geometry, vector analysis, and spatial reasoning.
mohamed el teir
in 3D assume two skew lines L1: x=x°+at, y=y°+bt, z=z°+ct, L2: x=x°°+ds, y=y°°+es, z=z°°+fs. therefore L1, L2 parallel vectors are respectively: v1= <a, b, c>, v2= <d, e, f>. if v1.v2= ad+be+cf= 0 (vectors are perpendicular), are the line L1, L2 considered perpendicular also or beside the dot product of their parallel vectors being zero the lines must also intersect (must not be skew) ??
The lines would be considered orthogonal, but that does not imply that they intersect.
Consider the x and y axes. The intersect in the plane z=0. But if you raise the x-axis to y=0, z=1, it will never intersect the y-axis defined by x=0, z=0.
do you mean that in the case that x-axis is in its original position the x and y axes are perpendicular and intersect, and in the case that the x-axis is in y = 0, z = 1 the x and y axes are perpendicular and doesn't intersect ?
Yes. Perpendicular lines only intersect if they lie in the same plane.
Yes. That was your question, right? If orthogonal lines must intersect or not.
yes sort of that, if lines with perpendicular directions but the lines themselves are skew, are they considered perpendicular or not, so they are perpendicular, thank you
