- 20,009
- 11,142
Cleaner than electric? Mazda talks up gasoline engine fuel economy ambitions for SkyActiv 2
http://phys.org/news/2014-03-cleaner-electric-mazda-gasoline-fuel.html
At Mazda, the engine of the future is called the SkyActiv-G Generation 2, a follow-up to Mazda's SkyActiv-G Generation 1. For SkyActiv-G Generation 2, Mazda will adopt homogeneous charge compression ignition (HCCI) and an even higher compression ratio of 18:1 over SkyActiv-G Generation 1 high compression ratio of 14:1. Mazda said on its site that increasing the compression ratio considerably improves thermal efficiency. According to Autocar, it is likely SkyActiv-G Generation 2 technology could arrive in production before the decade is out..
For SkyActiv-G Generation 2, Mazda will adopt homogeneous charge compression ignition (HCCI) and the higher compression ratio of 18:1. Autocar said The HCCI system works in a way similar to a diesel engine, using piston compression rather than a spark plug to ignite the mixture in the chamber.
a wink
