I Smoothing Numerical Differentiation Noise
The discussion focuses on the challenges of smoothing numerical differentiation noise when analyzing the intensity profile of a rectangular laser beam using the "knife-edge" technique. The initial data appears too noisy after differentiation, leading to questions about appropriate smoothing algorithms. Suggestions include using cubic splines, averaging adjacent data points, and applying linear regression to improve data quality. The conversation highlights the importance of measurement accuracy and the impact of data granularity on derivative calculations, suggesting that the discreteness of values may stem from rounding errors in the measurement process. Ultimately, obtaining more precise measurements and refining data collection methods are emphasized as crucial steps for accurate beam profile reconstruction.
roam
I am using the "knife-edge" technique to find the intensity profile of a rectangular laser beam. The data that is obtained using this method is power, the integral of intensity. Therefore, to get the intensity profile we must differentiate the data.
So, as expected, my data looks like a ramp (integral of a rectangular function). But when I performed the numerical differentiation on the data the result was too noisy:
This doesn't really resemble the actual beam that we have. This is more like what is expected from a rectangular/tophat beam:
So, what kind of smoothing algorithm can I use on the differentiated data? How do we decide what smoothing would be the most appropriate and accurate in this situation? :confused:
Any help is greatly appreciated.
P. S. I could try to obtain more data points, but I am not sure if that would help. I've used this technique before on Gaussian beams (this time, the raw data was an error function erf) – I had far fewer data points, yet I didn't get this much noise. Why?
Mathematics news on Phys.org
Your derivative appears to be very discretized: it can assume five different values. The second picture shows a granularity of more than a hundred steps. In the third picture there are only seven different values for the derivaative. Not much either.
Can you increase the intensity, improve the scale on the sensor, or something like that ?
Likes FactChecker and roam
A smaller number of data points means a larger difference between them - noise plays a smaller role. That is something you can do with your data, e.g. combine three adjacent bins to a single bin. Alternatively use one of the many smoothing methods. Just taking a weighted average of bins around your bin should give a nice approximation already.
Likes roam
What you do is fit the original data with something much lower order than the number of data points. Looking at your data, I would recommend a cubic spline with say 5-10 nodes. You then differentiate the low order function analytically.
Likes roam
Thank you for your suggestions.
So, if I understand correctly, we replace each element with the average of the three adjacent elements. i.e.,
$$\left(y\left(1\right)+y\left(2\right)+y\left(3\right)\right)/3\to y\left(1\right)$$
So we will have ~3x fewer data points to plot. Is that correct?
What if we use Matlab's smooth(.) function with a span 3 moving average filter? This would also be a 3-point smoothing algorithm except we have the same number of data points as we started. Is this method more or less accurate than combining the points?
Here is what I got (smoothed = magenta, original derivative = brown):
I need to reconstruct the actual beam profile as accurately as possible.
I can try finding a better power meter. Maybe a digital would be more helpful (this is from an analog output and it is hard to read off minor changes in power).
If I was to use some kind of adjacent average smoothing, would it be helpful to collect more data points?
More readings for the same curve will probably help.
A slightly more aggressive smoothing should help as well.
By more aggressive do you mean taking a larger span? I mean, instead of averaging 3 points, you could average a larger number of points.
How would you decide what is a good place to stop smoothing? I've noted that beyond a certain point (in my case, ##\text{span}=33##), you will not see any additional changes to the plot.
For example, yes. You can also average over points with different weights for them (larger weights for points nearby).
What is best depends on your application.
Likes roam
I would start with a linear regression on the data, then the derivative is just the slope of the line. Check out the r2 value of the regression. Then (looking at the curve) do a third degree regression. Now the derivative is analytically calculable. Again, check the r2 value of this regression. If it is better (higher), stay with the third degree, otherwise use the linear fit.
Likes suremarc and roam
As @BvU pointed out, your data is very crude. I think that you need to address that before post-processing. Smoothing may just be "putting lipstick on a pig." It may mask the information that you are looking for.
Likes roam
So, the idea is to use symbolic differentiation to avoid the noise problem in the numerical computation?
As you suggested, I did fit the data using polynomials of different degree, and here are the first few R2 values:
\begin{array}{c|ccccc}
\hline \text{degree} & 1 & 2 & 3 & 4 & 5\\
\hline R^{2} & 0.9885 & 0.9941 & 0.9945 & 0.9945 & 0.9969
\\\hline \end{array}
I went up to degree 9 and R2 kept increasing. But that might be because we are just modeling the noise in the data at that point.
For the quadratic for instance, you have an equation of the form ##ax^2 + bx + c## which has the analytic derivative ##2ax+b##. But when I plot it, I get this which doesn't look anything like the beam profile:
What is wrong here? :confused:
That is true. But in what way would you say my data is crude?
My data looks like ramp, and this is what I would expect if the beam has a nearly rectangular intensity profile (my signal is its spatial integration). I am not sure in what way I could improve the data except collecting more points...
roam said:
What is wrong here?
Basically nothing. You fit a parabola, you get a parabola. What you want to fit is ideally an almost square block with a lot of detail (*). Try to see what kind of integrated function that would yield.
(*) Detail that is not present in your data: steep edges, with possibly some small deviations on the flat part.
In short: you need higher resolution in both directions: less coarsely rounded off data points an a lot more of them
Likes roam
Sorry, I didn't realize that the derivative was not the raw data. Your calculated derivative numbers have very little resolution -- only 5 descrete values. That is very crude data to work with. In general, taking a derivative, whether symbolically or calculating, will introduce significant noise. Trying to smooth the noise out later is just undoing the derivative, perhaps in a bad way.
Likes roam
The linear regression shows a very high value for r2, so use that for a basic approximation.
Now I (being curious) would subtract the linear regression values from your data and do an FFT on the differences. The lower frequencies of the transformed data might tell you something (try throwing away everything but the three lowest frequencies and transform that back).
Hi Svein,
So what is the idea behind subtracting the regression from the data? And are we discarding the high frequencies as being noise?
I did what you suggested. In the DFT, I only kept the 3 lowest terms next to the DC term. Here are the results:
How can we use this information to reconstruct the beam profile?
Well, you know much more about the experiment than I do. What I was looking for in the DFT was some regularity in the deviations from the straight line, but there does not seem to be any. My conclusion would be that the linear regression is a very good fit to your experimental data (an r2 of 0.9885 - there are sciences where an r2 of 0.1 is considered exceptionally good) and the deviations are due to noise/measurement accuracy.
Likes suremarc, roam and FactChecker
I agree. I think that the deltas for the derivatives being such a small set of fixed values shows that the measurement accuracy is a limiting factor and will not allow better results.
Likes roam
During my measurements, the increase in data points appeared to occur at fixed increments (that's how I recorded the data). That was the best I could do with my measuring instrument – it wasn't possible to record the values precisely (i.e. using longer decimal format). So, is this what causes the discreteness of the derivative values?
Any explanation would be appreciated.
What would the regularities tell us though? As shown in the second figure in my first post, the fluctuations in a tophat beam aren't regular usually...
I guess the only option would be to obtain more precise measurements (more decimal places). I don't see a benefit to using a linear regression in this problem because the analytic derivative would just be a straight line that looks nothing like a beam profile. The analytic differentiation seems to be less useful here than its numerical counterpart.
It certainly appears that way.
To keep things simple, suppose one is measuring values between -1.5 and +1.5 but the recorded values are always rounded to the nearest integer -1, 0, +1.
There are only the following 9 cases of (rounded value of ##y_{i+1}##, rounded value of ##y_i##): $$(-1,+1), (-1,0), (-1,-1), (0,+1), (0,0), (0,-1), (+1,+1), (+1,0), (+1,-1).$$ They give the 5 cases for ##y_{i+1} - y_i##: -2, -1, 0, +1, +2.
It appears that these 5 cases correspond to the 5 values that you are getting (except that your Y values trend upward so the deltas are always nonnegative). So it looks like the recorded values are always rounded to values that do not allow very much resolution for the derivative. Any detailed conclusions you reach by analysing the derivative may be saying more about your rounding process than about the derivative itself.
Likes roam
Trying to calculate derivatives on measured data is the equivalent of a high-pass filter: Only the noise gets through.
If you insist on trying to calculate derivatives directly from the data, I'll give you a tip: Instead of doing f_{n}'=\frac{f_{n+1}-f_{n}}{x_{n+1}-x_{n}} (which calculates the secant, not the tangent), try using f_{n}'=\frac{f_{n+1}-f_{n-1}}{x_{n+1}-x_{n-1}} which gives a much better approximation to the tangent.
Likes DrClaude and roam
This is not truly a direct answer but I would recommend something along the lines of reading the eighth chapter in
Davis "Interpolation and approximation ";
https://www.amazon.com/dp/0486624951/?tag=pfamazon01-20
Which is my favorite goto although I am sure that there are probably better books now. The point is that you can choose a sequence of estimators/models, say polynomials of successively higher degrees for instance; take your test models and work from that. The models only have to be linearly independent for this theory to work. Having that in hand you can find the least squares fit/coefficients for the sequence via. a "Gram Matrice" and invert. Once done this model could be reused in similar situations.
Having said that, at the end plot the residuals in "normal probability plot" or nowadays a "Q-Q" plot and see if your residuals fall within the straight line error limits. The "normal probability plot" is my preference since it is really easy to read. Probably you should also try an autocorrelation on the residuals.
Look carefully, if there are systematic variations then you have an opportunity to improve something; i.e. more terms, different modeling sequence.
Improvement beyond a Gaussian (or other physically meaningful error models) is likely worthless. You would be digging in the mud for pearl and would probably find a marble (or worse). Now all of this says you have a simple unencoded type of systems.
You still have to be careful because: if you have Gaussian physical positioning errors and Gaussian electronic/reading noise this will not separate them. There are things you can do; average each individual point by a very slow filter or many readings and averaging. At each point! This is the way to cut down on instrumentation noise. If that's inconvenient rerun your data over and over, and average point by point; this cuts down of instrumentation noise but doesn't reduce instrumentation systematic errors. Truthfully, unless your willing to do this, i.e. reproduce results, you can't expect readers to give reasonable help.
Somewhere I read that Bessel functions (J() ?) can provide a basis for Laser Beam intensity profiles, but I don't remember where and have no experience with these profiles.
Hi. I'm interested in this problem, so I wanted to ask you a few questions.
I am willing to understand this experiment you are doing. This distribution you are looking for, is the spatial intensity for a laser beam, so when you say this, what you mean is that if for example you are illuminating with this laser to a wall, the shape of the intensity would be something like ##I(x,y)=A e^{-x^2/\sigma^2}e^{-y^2/\sigma^2}##? I don't understand how you would get this from the data you showed.
Do you know of any reference where this experiment is explained? perhaps we can help you if we understand a little bit better what you are doing and the physics behind it.
So a quadratic fit seems to fit your data quite nicely, therefore the trend through any interval is approximately quadratic. I ask, therefore, what numerical algorithm did you use to calculate the derivatives? The most elementary one, the one I suspect you used, is a forward difference approximation in which the secant between (x,f(x)) to (x+h,f(x+h)) serves as an approximation to the tangent at x. That is, if h is the interval between the abcissae of neighboring points, calculate f(x) and f(x +h) subtract f(x) from f(x+h) and divide by h. Now, let's think geometrically about how well this will fit a curve. If the 'curve' is a straight line, the fit is exact. If the curve has a non-zero second derivative, the FDA is guaranteed to be wrong, how wrong depending on the magnitude of that second derivative.
A central difference approximation requires you evaluate f(x-h) and f(x+h) subtract f(x-h) from f(x+h) and divide by 2h. The intermediate value theorem guarantees that somewhere between x -h and x +h there is a value, c, for which the slope of the secant between (x-h, f(x-h)) and (x+h, f(x+h)) exactly equals the derivative of f(x) at x=c. The CDA doesn't tell us what c is; but at least we know it's somewhere in the symmetric interval around x. In fact, if the curve is a quadratic polynomial, the slope of the CDA secant is the derivative at the midpoint of the interval exactly. Even when the overall f(x) is not quadratic, a quadratic is a good approximation to any well-behaved function anywhere, and the error in the approximation decreases as the interval gets smaller (Think of the first 3 terms of a Taylor series approximation.) To reiterate the clue in the first sentence, your function is approximately quadratic, so the CDA is particularly appropriate. I don't have your data, or I'd try my hand at it. Try it and see if it improves the noise figure of your derivatives.
Likes Telemachus and roam
Hi Svein and Mark Harder, thank you so much for the thorough explanations.
Yes, indeed I had used the forward difference approximation as the simplest approximation for the 1st derivative. In fact, I had generated vectors of differences using diff(.) in Matlab, so that diff(f)./diff(x) would be equivalent to FDA. I will instead try the central difference approximation and see how it goes.
Also: if I obtain high precision data and want to use symbolic computation, would differentiating a quadratic polynomial work? It clearly didn't work using the current data (my post #11)...
@Mark Harder I could send you my data if it helps, but as others suggested I think it is better to obtain more precise data first. I am using high energy lasers so using current modulation I should be able to lower the power and use a very sensitive meter.
@Telemachus Sure thing. Since this thread is under a mathematics forum, I will message you the details of the physics of the setup.
Likes Telemachus and FactChecker
It would not. Differentiating a quadratic polynomial gives you a straight line. Get it in your head that if you don't see a good profile, all the math in the world won't help you to bring it out from this single very coarse set of data.
Likes roam
Good. I agree that getting some data with greater resolution is essential. If you try to use higher order models on data where the largest part is due to round-off, you will get a mess. That being said, the suggestion of using data i-1 and i+1 to estimate i would double the true change of the function value and make the round-off half as significant. (It's also a better way to estimate the slope at point i.) Likewise, using i-2 and i+2 would improve things by a larger factor. But if you carry that to the extreme, you will miss local changes in the function.
Likes roam
Hi again. I already gave a read to your pm. I think the physics is actually important, because it could tell you what function you should be expecting, and what type of function to use for your data. For example, if the data were instead of this intensity profile, just some records for position and time in a free fall at the Earth surface, you would know that it should be a parabola from the physics, and interpolate a parabola, no matter how coarse your data is.
I think that knowing more about the physics in this situation is actually something very important to do the data analysis. Do you have any clue of what type of function you should be expecting?
Likes roam
Yes, I agree. Having more data and/or better quality data is the best solution if you can do it. You can also increase the also increase the quality of the data by increasing the sampling time for each measurement. The signal/noise ration increases as the square root of the counts (or continuous time). So you'd need to collect four times as long at each point to double the S/N ration. After a while, the time needed becomes impractical; but if you can, spending more time collecting at each point will 'smooth' the data without any risking the distortion of your original data or introducing biases into the experiment.
Likes roam and FactChecker
Roam, I forgot to mention that I was assuming in my analysis that the x-intervals in your measurements were all equal. If the intervals between points vary across the data, then the problem is more like an interpolation.
Likes roam
