Sodium hydroxide and hydrochloric acid
The discussion focuses on the thermodynamic analysis of the reaction between sodium hydroxide (NaOH) and hydrochloric acid (HCl). Participants explore the calculation of delta H values for three different scenarios: dissolving solid NaOH in water, mixing aqueous NaOH with HCl, and combining solid NaOH with HCl. It is concluded that the delta H values from the first two reactions should approximately equal the delta H of the third reaction, accounting for experimental error.
  • Understanding of thermodynamics and enthalpy changes
  • Familiarity with chemical reactions involving strong acids and bases
  • Knowledge of calorimetry techniques for measuring heat changes
  • Basic skills in handling and preparing solutions of NaOH and HCl
  • Research the principles of calorimetry and its applications in measuring delta H
  • Study the enthalpy of neutralization for strong acid-base reactions
  • Learn about experimental error analysis in thermodynamic measurements
  • Explore the use of Hess's Law in calculating reaction enthalpies
Chemistry students, educators, and laboratory technicians involved in thermodynamics and reaction energetics.
Jan Hill
We break down the rxn of NaOH with HCl into putting solid NaOH pellets in water and determine the delta H value. Next, we mix aqueous NaOH with a HCl (aq) and determine the delta H.
Then we mix solid NaOH pellets in HCl(aq) and measure the delta H. Can we say that the delta H values for the first two rxns should add up to roughly the value of the third delta H allowing for some difference due to experimental error?
The answer is '42'.
25K
