Solar Cell Physics Coursework (Calculating Internal Resistance)
3 replies · 5K views · last reply
elyas22
Basically I want to Calculate the internal resistance of a solar cell.
I set up a circuit with a voltmeter across the solar cell and an ammeter and variable resistor in series with the solar cell. The variable resistor is the load.
Image at http://elyaschaudhary.schools.officelive.com/video.aspx
As i change the resistance the value of current changes which is GOOD
However the Voltage stays the same BAD
This results is a graph with a horizontal Line implying that internal resistance is 0. BAD
I need the current and voltage to change i think to get a graph which will be able to give me the EMF and Internal resistance.
Could some one please explain how this is done
Thank you very much
Elyas
How low in resistance did you go? If you short out the solar cell, you will definitely get a lower voltage.
If you replace the solar cell with a voltage source (V) and an internal resistance (r) in series, then calculate the measured voltage (V1), you will see that a constant V1 just means that the internal resistance r is small compared to R. You will need to do the experiment again with smaller values of R that do cause a change in V1 in order to calculate r.
