Solenoid Induction Homework: Bz & Flux Calculation
Bryon
A solenoid has length L = 20 cm, radius 6 cm, and N1 = 4500 turns; its axis coincides with the z-axis. A circular conducting loop containing N2 = 11 turns of radius a = 1 cm is centered inside the solenoid; the plane of the loop makes a 30° angle with respect to the z-axis.
The current in the windings of the solenoid is varying with time according to the expression
I1(t) = 0.45 A + 0.14 (A/s) t.
Biot-Savart(Center of a solenoid): Bz = u0nI
Magnetic flux: ϕ = ∫BdA= NBAcosϑ
(a) Calculate the magnitude of the magnetic flux Φm through the loop at t = 3 s. (Absolute value)
I1(3s) = 0.45 A + 0.14 (A/s) (3s) = 0.87A
Bz = 4*pi*10^(-7)*(4500/0.2)*0.87 = 0.02459867 T
ϕ = (0.02459867 )*pi*(.01^2)*11*cos(30) = 7.3618137e-5 Tm^2
I did something wrong and I am not quite sure where. Any ideas?
I think i understand the concept. Since there is a small loop inside the solenoid at angle ϑ, I need to find the magnetic field at the center due to the current in the solenoid. Then I just have to find the total flux through the total area of the small circular loop that is sitting in the middle of the solenoid.
The question does provide a hint: Approximate this finite solenoid by an equivalent infinite solenoid to find the magnetic field in the central region.
Does this mean I can use a portion of the number of turns over a small distance to find the magnetic field?
on Phys.org
Need the picture?
Help?
Are you sure that the magnitude of the flux through the small loop depends upon the number of turns in that loop?
Hmmm. I am not entirely sure. The equation for magnetic flux calls for it, but I think that is for the solenoid itself.
I know that the magnetic field is uniform with in the solenoid near the center, and that would mean that the loop will see what ever its area is.
I think I just answered your question! Thanks it makes a lot more sense now.
