Solid State Physics [Ashcroft] Chapter 1, Question 1a
The discussion focuses on the application of the Drude model in solid state physics, specifically addressing the probability of an electron experiencing collisions over time. Participants derive the probability expression exp[-t/T] for an electron selected at a random moment, demonstrating that it has not suffered a collision during the preceding t seconds. The conversation emphasizes the use of discrete time intervals and the limit process to arrive at this exponential probability, as well as the relevance of the Poisson distribution in this context.
  • Understanding of the Drude model in solid state physics
  • Familiarity with probability theory and exponential functions
  • Knowledge of limits and calculus, particularly in the context of infinitesimals
  • Basic concepts of Poisson distribution and its applications
  • Study the derivation of the exponential probability in the context of the Drude model
  • Learn about the Poisson distribution and its relationship to collision probabilities
  • Explore advanced topics in solid state physics, such as electron scattering mechanisms
  • Review calculus concepts related to limits and infinitesimal analysis
Students and researchers in solid state physics, particularly those studying electron behavior and collision probabilities in materials, as well as educators looking for tutorial approaches to teaching these concepts.
FONE
Hi all,
Edit: Here's the question, in case you guys don't have the book:
In the Drude moel the probability of the electron suffering a collision in any infinintesimal interval dt is just dt/T.
a) show that an electron picked at random at a given moment had no collision during the preceding t seconds with the probability exp[-t/T]. Show that it will have no collision during the next t seconds with the same probability.
I'm trying to figure out how to get the exp[-t/T] part, 'cause nowhere in the chapter does it show a probability as XX exp[-t/T].
Please just help me get started. Any reference equations would be good...
Thanks!
Lets say our randomly picked electron was selected at time t_0, and we want to find the probability that this electron suffered no collisions from t=0 to t=t_0.
We know that the probability an electron to be scattered in an infintesimal interval dt is
<br /> P_{c}(t,t+dt) = \frac{dt}{\tau}.<br /> [/itex]<br /> <br /> Now the probability for the electron to suffer a collision, and the probability for it not to suffer a collision in this interval must sum to 1. So<br /> <br /> &lt;br /&gt; P_c(t,t+dt) + P_{nc}(t,+dt) = 1 &lt;br /&gt;<br /> <br /> Hence,<br /> &lt;br /&gt; P_{nc}(t,t+dt) = 1 - \frac{dt}{\tau}.&lt;br /&gt;<br /> <br /> Now I will split the time interval [0,t_0] into M discrete intervals, such that<br /> <br /> &lt;br /&gt; t_0 = \sum_{n=1}^{M}dt = Mdt.&lt;br /&gt;<br /> <br /> If I label the probability to not scatter in the interval [0,ndt] as P_n, then I have<br /> <br /> &lt;br /&gt; P_1 = (1-\frac{dt}{\tau}),&lt;br /&gt;<br /> <br /> and<br /> <br /> &lt;br /&gt; P_2 = P_1\times (1-\frac{dt}{\tau}) = (1-\frac{dt}{\tau})^2&lt;br /&gt;<br /> <br /> The probability to not scatter from t=0 to t=Mdt=t_0 is<br /> <br /> &lt;br /&gt; P_M = \ldots&lt;br /&gt;<br /> <br /> Once you have your expression for P_M, eliminate from this expression dt using the definition of t_0, and notice that <br /> <br /> &lt;br /&gt; \lim_{dt\to 0} \equiv \lim_{M\to\infty}&lt;br /&gt;<br /> <br /> Then you will have the limit of some function to evaluate...
Hey,
Thanks for that! So if I divide up the t0 time into intervals, I can use the infinitesimal probability:
P(t, t+t0) = P(t, t+ndt) {n--> infinity}
so:
P(t, t+ndt) = (1-dt/T)^n, now we sub the definition of t0
P(t, t+t0) = (1 - t0/nT)^n, taking the lim n--> infinity
P(t, t+t0)=exp[-t0/T]
How do I distinguish between "before" and "after" t0 seconds? It looks like it's the same both ways, but how do I be rigorous about it?
Thanks!
Just use the same logic as before. You have an expression for the particle not to have a collision from t=0 up to t=t_0 . Consider the probability for not scattering from t=0 to t=2t_0 (using the expression you derived). Express this in terms of the probability of not scattering from t=0 to t=t_0, and the probability not to scatter from t=t_0 to t=2t_0.
Or you could use a Poisson distribution to evaluate the probability. Then you get the exponential function naturally from the poisson distribution.
Ruy said:
jpr0
would you have the other problems of the I capitulate 1 and could it post for me?
Welcome to the PF, Ruy. We do not provide answers here on the PF, we provide tutorial help. If you have a specific problem that you need help on, please start a thread with the question, using the Homework Help template, and show us what work you've done so far.
Somebody would have the subject 1c 1d 1e
1c)show as consequece of (a) ...
1d) show as consequence of (b) ...
1e) part (c0 implies that...
Thanks
Thanks
I'm not sure what you are asking. What is your question? It is probably best for you to start a new thread here in the Homework Help forums, use the Homework Help question template that is provided, and show your work so far so that we can help you in a tutorial way.
Hi every body, I am new comer and be interested in Solid State Physics [Ashcroft]. Has anyone have solution for the book. chapter 9, Problem 2(Density of levels...)?
I am confused by intergarating delta function with separated variable as shown in.
thank you
Welcome to the PF, Repetit. You should start a new thread with your question. Be sure to use the Homework Help Template that you are given when starting new homework question threads, and fill out the sections on the Relevant Equations and show your Attempt at a Solution.
We certainly don't do your schoowork problems for you, but we can usually offer tutorial hints that will help you to do the work yourself.
12K
