Solubility of Cations/precipitation question
  • Thread starter supernova1203
    Solubility
supernova1203
The question is asking us to determine weather there is a Li+ Ion or Sr+2 ion in the solution
We are using the precipitation method
Using various solubility tables I determined that Sr+2 ion is not soluble with the sulphate ion
SO-24
the course book uses the compound Na2SO4
my question is, they intentionally use sulphate ion because they know if there is Sr+2 ion in solution, there will be a precipitate, if there isn't then there will be no precipitate, but why did they use sodium? Couldnt they have used any group 1 Metal? since any group 1 metal would have been soluble with Li ion?
Iv run into similar questions down the line now, you can always just put one ion that isn't soluble and find the precipitation, but why do they put the other element in there? Like they did in the problem described above, where they put in sodium along with sulphate?
I add a screenshot for further clarity
Here is another example, where they do this again, they just need to add
C2H3O2
but they also add a Na to each stage when testing for a certain Ion in a solution, to see wheather or not a precipitate forms
There is a typo for the H3
in the book it should be C2H3O2
but it says H5
Why do they add the extra sodium? i don't get it..
  • Flowchart for identifying Ag+, Ba2+ or Mg2+ in a solution: add NaC2H3O2, then Na2SO4, then Na2CO3, with precipitate or no precipitate at each step indicating which ion is present or absent.
well i didnt know that i couldnt, i had forgetten from earlier lessons what an ionic compound was,(i have a terrible memory) anyway i figured out eventually that you need to have an element from group 1 or 2 and make an ionic compound with sulphate and then you can proceed to see if precipitation occurs or not
Actually you could use any sulfate, or even sulfuric acid. But that means troubles - other cations will just increase number of possible precipitates, sulfuric acid will acidify the solution, in both cases the analysis becomes more and more difficult as the number of factors one has to take into account grows. Sodium compounds are cheap, and soluble - so usually they are preferred over anything else.
