Effect of Solutes on Solution Solubility: Acetone Evaporator
  • Thread starter Thread starter Praestrigiator
    Solubility
The discussion centers on the impact of solute concentration on the solubility of other solutes in a solution, specifically in the context of designing an acetone evaporator for thermal management. It is established that the humidity of the intake air significantly affects the performance of the evaporator, particularly in humid summer conditions. While the common ion effect is acknowledged, there is a lack of comprehensive models to predict the behavior of non-ideal mixtures, indicating that experimental parameters play a crucial role. The conversation emphasizes the uncertainty in predicting the effectiveness of the acetone heat rejector without empirical data.
  • Understanding of solubility principles and the common ion effect
  • Familiarity with acetone properties and its applications in thermal management
  • Knowledge of heat exchanger design and operation
  • Basic principles of non-ideal mixtures and their modeling
  • Research the common ion effect in detail and its implications on solubility
  • Explore experimental methods for measuring solubility in non-ideal mixtures
  • Investigate heat exchanger designs suitable for acetone evaporation
  • Study the impact of humidity on evaporative cooling systems
Engineers, chemists, and thermal management specialists involved in designing evaporative cooling systems, particularly those utilizing acetone and dealing with varying humidity conditions.
Praestrigiator
Does the amount of one solute in a solution effect the maximum quantity of another solute that can be dissolved ino that solution, or the rate of dissolution?
To provide context: I'm thinking of making an acetone evaporator for thermal management purposes. I'm wondering if the humidity of the intake air would be relevant in the effectiveness of the cooler, especially since I would mostly be using it in the summer, when the air is remarkably humid here.
Chemistry news on Phys.org
Short answer: yes, it does.
But apart from relatively simple cases (common ion effect) I am not aware of any model describing the behavior of such solutions, and intuition tells me even if they exist (highly probable) they are heavily relying on experimental parameters (as most models dealing with non-ideal mixtures do).
Hopefully I am wrong.
Hmm, so I'm SoL when it comes to predicting the effectiveness of my acetone heat rejector? I love the 'build it and hope for the best' method of engineering. It's my favorite.
Does the air contact the acetone directly, or is there a heat exchanger with with acetone evaporating on one side of a wall and air cooling on the other side?
  • · Replies 32 ·
  • · Replies 28 ·
  • · Replies 19 ·
