MHB Solution Set in interval notation for inequality
To solve the inequality 6x^2 - 2 > 9x, it is rewritten as 6x^2 - 9x - 2 = 0. The roots are calculated using the quadratic formula, yielding approximate values of -0.1964 and 1.6965. The quadratic expression represents an upward-opening parabola, indicating that the solution set excludes the interval between the roots due to the strict inequality. The final solution set in interval notation is expressed as (-∞, (9 - √129)/12) ∪ ((9 + √129)/12, ∞). This indicates the regions outside the roots where the inequality holds true.
datafiend
HI all,
I have the equation, 6x^2-2>9x for which I'm to find the solution set in interval notation.
I've rewritten the inequalty as 6X^2-9x-2=0. I tried to factor, but no go. Then I used the quadratic and got 9+/- rad(129)/-18. The answers I get for x are -1.1309 and .1309. The calculator gives. -.1964 and 1.6965. Is this just some rounding error?
Thanks,
Mathematics news on Phys.org
It should be $\dfrac{9\pm\sqrt{129}}{12}$. Your calculator is correct for approximate values.
You did well to move the $9x$ to the left so that you have:
$$6x^2-9x-2>0$$
Now, observing that expression is a quadratic, and that its graph will be parabolic, we see that it is an upward opening parabola since the coefficient of the squared term is positive. Thus, the expression must be negative in between the roots. Having the correct roots of the expression now, can you state the solution in interval notation?
I think -9+/-\sqrt{129}/-12 to negative infinity/positive infinity. Basically, the area between the pos and negative is excluded. Yes?
The region between and including the roots is excluded because we have a strict inequality. To express this using interval notation, we would write:
$$\left(-\infty,\frac{9-\sqrt{129}}{12}\right)\,\bigcup\,\left(\frac{9+\sqrt{129}}{12},\infty\right)$$
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
