Solution to polynomial of unknown degree
  • Thread starter Thread starter Jhenrique
    Degree Polynomial
The discussion centers on whether it is possible to solve the polynomial equation y = Ax^a + Bx^b for the variable x, given that a and b are real numbers. It is noted that isolating x is generally not feasible unless the exponents are specific positive integers, particularly if they are both less than five. For lower degrees, such as quadratic equations, solutions can be easily found using the quadratic formula. The conversation also touches on advanced mathematical concepts like Newton-Puiseux's Theorem for deriving power series representations of solutions. Overall, while some cases allow for solutions, many scenarios present significant challenges.
Jhenrique
Dear!
Is possible to solution a polynomial of kind y = Ax^a + Bx^b ?
Thx!
Mathematics news on Phys.org
You have sevens unknowns and one equation.
Could you solve 0 = a + b + c + d + e + f + g + h?
Jhenrique said:
Dear!
Thx!
I assume you are asking if it is possible to find the zeroes of y(x) = Ax^a + Bx^b, where a,b are real numbers?
If it's a polynomial then a and b are natural.
Jhenrique said:
Dear!
I count six: A, a, B, b, x, and y.
omg, my question is simple!
I would like to know if is possible to isolate the x variable in equation
f(x)=ax^{\alpha}+bx^{\beta}
In general, no. If \alpha and \beta are both less than 5, then yes. If they're both less than three, then it's a quadratic or simpler and hence easily done by the quadratic formula. In most other cases it's either difficult or impossible.
Yes, it's possible, and quite easy. Let us suppose that \alpha > \beta. Let \zeta = e^{2\pi i/(\alpha - \beta)} be a primitive root of unity. Then the polynomial factors as:
ax^\beta \prod_{k=1}^{\alpha - \beta} (x - \left( \frac{b}{a} \right)^{1/(\alpha - \beta)} \zeta^k)
In mathematics, as in other areas of science, just because a question is 'simple', it does not necessarily follow that the solution will be 'simple'.
For example, consider Fermat's Last Theorem:
http://en.wikipedia.org/wiki/Fermat's_Last_Theorem
He's not looking to factor the polynomial but rather to find the inverse f^{-1}(x), I think...
Yeah!
Yes if the exponents are positive integers. Consider the general algebraic function, ##y(x)## written implicitly as:
$$f(x,y)=a_1(x)+a_2(x)y+a_3(x)y^2+\cdots+a_n(x)y^n=0$$
with ##a_i(x)## polynomials. In your case we would simply have:
$$f(x,y)=x-ay^{\alpha}-by^{\beta}=0$$
Then by Newton-Puiseux's Theorem, we can compute power series representations of the various branches (solutions) of ##y(x)## having the form:
$$y_d(x)=\sum_{n=-p}^{\infty} c_n\left(x^{1/d}\right)^n$$
with radii of convergences extending at least to the nearest singular point of ##f(x,y)## and often further than that.
Do a search for "Newton Polygon" if you're interested in knowing how to compute these "Puiseux" series.
