How Do Mole Fractions Determine Vapor Pressure in a Binary Solution?
The discussion centers on calculating mole fractions of benzene and toluene in an ideal solution at 80°C, where the vapor pressures are 800 mmHg and 300 mmHg, respectively. The vapor pressure of the solution is given as 400 mmHg. Using the equation Pv = xaPa + xbPb, the correct mole fractions are determined to be 20% benzene (0.2) and 80% toluene (0.8), confirming option D as the solution. The discussion emphasizes that mole fractions do not require knowledge of moles or masses, only their ratios.
  • Understanding of ideal solutions and Raoult's Law
  • Familiarity with vapor pressure concepts
  • Knowledge of mole fractions and their properties
  • Basic algebra for solving equations
  • Study Raoult's Law and its applications in vapor pressure calculations
  • Learn about ideal vs. non-ideal solutions
  • Explore the concept of partial pressures in gas mixtures
  • Investigate the relationship between temperature and vapor pressure
Chemistry students, chemical engineers, and anyone studying thermodynamics or solution chemistry will benefit from this discussion.
brake4country
Benzene and toluene combine to form an ideal solution. At 80 C, vapor pressure of pure benzene is 800 mmHg and the vapor pressure of pure toluene is 300 mmHg. If the vapor pressure of the solution is 400 mmHg, what are the mole fractions of benzene and toluene?
(A) 60% benzene and 40% toluene
(B) 50% benzene and 50% toluene
(C) 40% benzene and 60% touene
(D) 20% benzene and 80% toluene
Pv=xaPa + xbPb
I could easily back solve by trying each one out. D is correct. (0.2)(800) + (0.8)(300) = 400 but I really wanted to try this problem using the equation above. Instead of backsolving, is there an accurate way to put this formula to use? Thanks in advance.
Hint: xa + xb = ?
but we don't know the moles of either benzene or toluene. Is it safe to assume 100 g of each converted to moles?
You don't need moles nor masses. Deal with mole fractions only.
What is the definition of a mole fraction in a mixture? What do the mole fractions of a mixture always add up to?
  • · Replies 36 ·
13K
25K
