Solve 2^(5x)=3^x(5^(x+3)) Logarithm Exercise
The equation 2^(5x) = 3^x(5^(x+3)) is being solved using logarithms. The user attempted to apply natural logarithms but struggled to isolate x. They received a hint to use the property of logarithms that states log(ab) = log(a) + log(b). After some guidance, the user expressed confidence in their understanding of the solution process. The discussion emphasizes the importance of logarithmic properties in solving exponential equations.
0range
2^{5x}=3^x(5^{x+3})
ln2^{5x}=ln3^x(ln5^{x+3})
5xln2=xln3(x+3)ln5
Here's where I get stuck... I've tried a bunch of different manipulation, but can't seem to isolate x...
Thanks in advance!
Hint: Remember that log (ab) = log (a) + log (b) Check the RHS of your equation
Thanks for the direction! I think I've got it...
It's late and I still suck at LaTeX, is it okay to do this, or is it against etiquette?
Thanks again for your help!
Welcome to PF, Orange! :smile:
It is okay to do that, and you did get it.
Cheers!
Thanks!
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
